Reply Problems
Winchester, Hampshire
I tried to say Congratulations re Rory’s arrival but Tapatalk won’t let me.
I’d used an emoji that it didn’t seem to like and it flashed up an error message.
In the past when this has happened I just delete the emoji and post without it but for some reason I cannot post a reply with whatever I try to send.
Anybody else experience this problem?
Is the problem persisting Rod? Usually SQL errors mean that the forum ISP is having a problem. These normally clear by themselves but you can check here to see if they have a known problem.
http://status.1and1.co.uk/
hth
PS It could be that Tapatalk is having a problem instead so you could always try a normal browser and see if you get the same error.
I’ve tried it again and it still won’t let me send anything but it’s ok on other topics.
I’ll try on my computer later
Actually tried on my phone using Safari and worked ok - must be Tapatalk
Yep it’s Tapatalk. The post has emojis in it that SQL doesn’t like so even though you have deleted your emoji it doesn’t like the existing unsupported ones.
I had a brief look into it, loads of posts talking about the same and no solutions so I’m not wasting any time on it.
Thanks Mark - normally if I get that message I delete the emoji and it sends.
This time it wouldn’t send no matter what I tried.
I shall have to remember not to include them.
Happy Easter
