3/16" Chisel Making Project
rxh
As I am too mean to buy new chisels I like to buy old ones to restore. However, 3/16" size seems to be very hard to find so I made this one in O1 steel, with maple handle and brass ferrule. I lack the skills and equipment to forge a bolster so I made one as a separate "collar".
Well, that's the prettiest mortise chisel I've seen in a while, and it's a shiny piece of oak furniture you've put it on. Why 3/16ths, though? Have you lots of mortices of that size to chop out?
Aesthetically flawless!
You could probably charge a fortune for chisels of that quality if you decided to make them commercially.
:text-coolphotos:
That looks very nice!
O1 is such handy stuff, did you harden just the tip of the chisel or the whole thing and was it then tempered?
I’ve got an old ‘pig sticker’ about the same size; quite a handy bit of kit for cleaning out the debris from a deep mortice - Rob
Thanks for all your comments. I made a 3/16" chisel because I didn't have one that size and I has an offcut of tool steel of that thickness. I hardened most of it (but not the tang), bearing in mind the old Marples slogan: "good to the last inch" :) After quenching the red hot metal in cooking oil I tempered at 200 deg.C for an hour.
I made the "collar" over sized and turned it down to the diameter of the ferrule after assembly.
Nice work, I like the in progress shot.
Edit: I forgot to say but I’ve made quite a few small bits out of O1 or silver steel and I’ve left them glass hard and not bothered to temper them. Not had a failure so far but obviously it’s a bit different to something like a chisel. I’ve been thinking about making a spoon carving gouge and as it’s only got a fairly short useful edge I’d probably only harden and temper the tip.
Exemplary work as ever. I really like your collar instead of a bolster.
Thanks Woodster - I think the need to temper depends on the tool. I made a broach for making round holes square but after hardening it I dropped it on a tiled floor and it broke into three pieces, much to my displeasure. Its funny that you mention a spoon carving gouge - I made one recently and I'll show it in a separate post.
Thanks Andy - I have seen some commercial chisels with a collar instead of a bolster, presumably as a cheaper method of manufacture with the blade being stamped out of flat plate. This German chisel is an example:
This Soviet era Russian chisel takes a slightly different approach, with a sort of combined ferrule and collar:
Naah, they look cheap rather than stylish.
Did you file the square hole or broach it?
The Russian chisel has its price stamped into it: 52 Kopecks. It seems that prices were centrally stipulated and enforced over the whole USSR.
I made the collar hole square, or rather rectangular, by filing.
