3 phase plugs
max power
The motor that converts my supply to 3 phase has a 5 pin outlet but my new drill only has 4 wires.
Can I use a five pin socket on the drill and just miss one of the pins ?
Yes. The fith pin is for a neutral connection rarely found in uk 3 phase installations but standard in rest of Europe,
Just wire up the three phases and most importantly, the earth. Oh yes do use a plug on the drill not a socket!!
HTH
Thanks Bob, I was thought that would be the case, just needed someone knowledgeable to confirm
Thanks Bob, I thought that might be the case, just needed someone knowledgeable to confirm before I bought the plug
Mod Edit: this is a duplicate post but I've left it to help your post count.
New members have to have their first three posts approved.
Now that you have made three your future posts will will be published immediately.
Welcome to TWH2.
Why not post something to intoduce yourself in the welcome section and may edit your profile to give us a christian name and a rough location so that if needed members local to you can offer practical help.
