Wood Pigeon
- Joined
- Aug 23, 2026
- Messages
- 39
- Reaction score
- 33
- Name
- Charles
- LOCATION
- Schleswig — Holstein, in Germany
I have a KitchenAid K5 series mixer which has a lot of sideways torque, when mixing a kilogram of bread dough. It is a problem that various tables wanted to 'dance about' as the dough-hook spins around, slapping the dough against the side of the bowl with the sound of 'Irish tap-dancing ladies.'
So I built this solid little bench for it 80 x 59 cm, and 82 cm high, with carriage bolted L-profile legs, and reinforcement framework underneath for a shelf.
I used 7.4 cm x 19 mm fir boards for the frame, legs, and cross-members, put together with various length of SPAX screws, their holes all pre-drilled, and countersunk.
It would have been easier to buy a laminated fir top 80 x 60 cm, 28 mm thick, but it was easier for transport (without an auto, and only my homemade utility-wagon), and also cheaper, to buy 9.4 x 24 mm fir boards, and piece the top together myself.
The only problem is that, all dried and planed German lumber has a rolled edge, the so called 'Glattkant'. Being that I lack a planing machine to get rid of them, I hade to putty up the resulting grooves with wood dough.
It took my wife and I a whole hour at 'OBI' to select the nicest boards, but some otherwise perfect ones, indeed had missing knots on one edge.
There are four cross-braces under the table-top, which hold the top boards down with a total of 64 SPAX screws 35 x 4.5 mm, their holes being pre-drilled and countersunk. These 24 mm fir boards were so tough, I could hardly get some of the screws in.
Wood does indeed sometimes have a 'mind of its own', and many clamps were need to hold each board into place, which was laminated with 'UHU Wood Glue' and then secured with screws from underneath.
I built the top as such, board by board, laminating, clamping, and screwing them, one by one.
The result is very nice. I shall give it three coats of the 'Bondex' clear, high-gloss, marine varnish, which I used on all of my other counter-tops. It is indeed gasoline, diesel, oil, sun, and salt resistant (which never comes about during my cooking. Haha!
And I have never had any problems with this varnish chipping, scratching, or knife marks either, but we do use cutting boards.
It received its second coat of marine varnish today, as seen in my photos
The legs and frame shall get two coats of 'Alpina Furniture Paint', in gloss white.
Charles
Charles
