Bubinga, 238mm. diam.
CSS, 3wheel buffed, Microcrystalline wax finish.
A truncated WIP in case it's of interest.
Due to thin Blank and not wishing to lose depth due to mounting spigot or socket, mount on support block with Hot Melt glue, also gives addition chuck side clearance for partially forming rear side. Make sure glue is very hot and bubbling.
Use tailstock centre to align and clamp, use rotating tailstock to support and turn peripheral details in case wood stresses take it out of round as you remove core wood.
Undercut rim asap for same reason, using close rest support and sharp tools, I work with lathe in reverse for this for ease of access and vision.
Remove remainder of core wood, maintaining safety support as long as possible.
Sand to finish and seal.
Part off from wood block and mount on Cole Jaws to work base, using tailstock support as much as possible for increased rigidity.
Abrasive Buff finish and wax polish with appropriate mops.
