Curvy plinth
mailee
Started a small job today, a curved plinth for a shower tray. It makes a change to get something out of the ordinary as I have just been boxing pipes in over the past few days. :D It is constructed in MRMDF and will be painted white to match the shower tray. :D
yes Bob, it is three laminations of 6mm. Will see in the morning how well it's gone. :eusa-pray:
I am just hoping I have allowed enough for the spring back once it's out of the clamps. I use the waterproof PVA Peter.
Well it looks half decent and there was about 1 1/2" spring back which isn't too bad as it will be flexed into place and that should hold it in place. :D
Thanks Mailee I thought it may have some spring back with the PVA but not an issue if as you say it will be fixed. 3mm MDF and a UF glue may hold a tighter curve if required in the future. As with all woodworking when doing it for a living make it the most cost effective way you can to suit the job. The West System is great but overkill in most circumstances.
Cheers Peter
Thanks Peter, I shall bear that in mind for the future. ;)
