Hi all,
I'm after some advice on cutting a door opening into a single brick wall in the garage. It's a very standard build garage, large 440 x 320 brick pillars in the corners of the garage and a smaller 440 x 200mm pillar in the middle of the wall running front to back. It'd be nice to have a side door as illustrated below. My question is, I just need building regs to check it? Should the process be to put in props above, cut out and fit lintel, fit door. Fairly straight forward?
TIA!
TIA!
