Eastern White Cedar headboard.
duke
Ontario, Canada
Duke
I have a good stock of 6"x 9' fence posts which is ideal for posts rails and slats. 1000009071.jpg
After cutting a length from the bottom I milled a flat surface on the jointer then ran it through the band saw.1000009072.jpg1000009076.jpg1000009074.jpg1000009075.jpg
Then off to the table saw to size it down to 3 1/8" square. Needed to wear a respirator due to the fine dust and overbearing aroma.1000009078.jpg
Needed to build the bedframe before finishing the headboard. Wanted a contrast in wood and texture. Legs are cedar posts, frame is cherry.1000009344.jpg1000009347.jpg1000009349.jpg1000009350.jpg1000009352.jpg
Yes, from the backside. Cabin-ish good description, never entered my mind while making the frame. :)
Back and front , decided to plug Cherry over the slat pins. The bed is finished.1000009386.jpg1000009387.jpg1000009393.jpg
I think I will lower the headboard about 3" to 4", I did a pillow stack for reading purposes and it will be fine to lower it.
