AJB Temple
- Joined
- Apr 15, 2019
- Messages
- 7,568
- Reaction score
- 1,073
I have a two part Georgian chest and top cupboard that I have not long ago acquired. I did some work on it today. It's a Gillows original (both stamped and plated) and my specific issue is I don't have keys for any of the locks. Does anyone have any experience of sourcing good quality barrel locks and fitting them to old locks. I am perfectly happy to hand file a key from a barrel key blank if that is realistic.
This cabinet has 4 locks. I would surmise that the keys are all the same, though the drawer locks and cupboard locks are slightly different. The drawer locks are all stamped or engraved Gillow, whereas the cupboard lock is the only one with a bulge and has no markings that I can see. This is the cupboard lock. The pin is about 3mm (imperial endnote measured it yet).
The bulge in the back probably hides a cam and I doubt if the lever mechanism is at all complicated. Unfortunately this one is riveted so to open it I will have to either do a bit of hammer and drift punch work or failing that, drill it off. The keep also needs replacing on this one. I might have to make that. Someone has very carefully filled in the keep cutaways with what appears to be boxwood.
I imagine some of you will have re-keyed locks? Any tips for making this job as easy as possible? I want to learn to do this myself rather than take it to a locksmith, as I have a few locks here and there of similar old type.
Adrian
Adrian
