Kitchen and Two Bathrooms Renovation.
Ah, right. That should look great. Although, if ours is anything to go by, it will be covered in clothes and stuff permanently, and never seen again! :)
Another boring post , well second of the last doors to be adjusted due to deflection of using green lumber. Floor had sunk 1 1/8" back in the 1910 s. 1000008222.jpg
Ah, the old Schluter Kerdi ! Used that on the west coast in DIL’s shower, it’s quite impressive stuff, I remember they make little alcove boxes for putting toiletries in in the shower too. Haven’t come across the stuff on the floor though, Ditra? For tiling on?
Looks a good job duke.
Ian, I always use the Schluter system, have for many years. I have never had a call back due to leaks etc. Best product around by far.
It does take a little longer to prep for tilling but well worth it.
The Ditra is amazing, no need to use a cement board of Hardi Backer board.
The shower pan is one unit, with adequate slope to the drain and water proof.
Also used their alcove that you have used.
There is a different Ditra board that allows for running electric heat cables which snap into a groove. I did a master bedroom and large bathroom using this system. Nothing like a heated floor.
That’s handy to know about not needing the Hardy backer board. I’ve always found it a devel to cut.
Also started on the drawer fronts, three for the above drawers and two for the mud room. Cut the dados with the table saw and assembled two. 1000008960.jpg1000008961.jpg1000008962.jpg1000008964.jpg1000008968.jpg
Hot water boiler system, presently oil fired soon to be converted to propane.1000011193.jpg
