Good evening all.
I’m looking to increase the size of an existing barrel channel in a rifle stock, currently it’s 34mm and i want to increase it to 38mm, i’ve bought a core box cutter to do so. However i’ve never used a cutter that large that’s going to be cutting on two sides at the same time. The stock is built from a dense ply type laminate which will cut and finish well.
Building a suitable jig to hold it and guide the router is no problem. Assuming i take light cuts of around 1mm at a time , is this likely to be problematic?
I do know someone with a suitable milling machine i can use , but with travel etc it’ll take me a full day, plus have to wait until it’s going to be available for me to use.
Cheers phil
Cheers phil
