duke
I will, ran out of stock. I have used the wipe on poly for a donkey's age. Gloss or satin is available, you must have it over there.Are you putting anything under the coasters, pads etc. We are always short on coasters they should be very handy. Wipe on Poly? never knew that existed.
Cork is the best option unfortunately the only place to get it that thin is at a craft store which is an hours drive. Which I always forget to do when I'm in that city.I found some 1mm thick cork sheets to stick on the base of mine.
I've seen loads of US and Canada youtube videos where they talk about wipe on poly being readily available in diy shops, but I've never seen it in our B&Q, Wickes, Screwfix etc.Are you putting anything under the coasters, pads etc. We are always short on coasters they should be very handy. Wipe on Poly? never knew that existed.
