Pinch
Mike G":1m1nowyk said:Pinch":1m1nowyk said:......... I now vaguely remember the nurse saying these things to me after I came round, but I wasn't really that compos mentis at the time. I wasn't sure if he said "you will experience abdominal pain afterwards" or if he said "if you experience abdominal pain, contact your doctor." This sheet now confirms if you experience 'severe pain in your neck, chest or abdomen' after the procedure, contact your doctor immediately.
Well, I had an awful night sleep last night - couldn't sleep on either side as I had discomfort and bad nausea (much worse than normal), so I had to sleep on my back. Problem was, as I nodded off, I would then turn over onto one side and the discomfort would wake me up, and so this continued through the night - bad night. I've also had a worse than normal discomfort all day. This evening, I've had to put on my braces so I can undo my trousers and lower the fly. :shock: :lol:
I've got so used to feeling discomfort in the abdominal area, so I'm unsure whether this is pain or just discomfort at a slightly higher level than I'm used to. I'm not curling over in agony which would be severe pain I guess, but it is forcing me to walk a bit odd and sit strangely, but then, I do anyway. I'll see how I go through the night.
Did any of you chaps experience similar after your examinations?
With the normal proviso (I am not a doctor), that doesn't sound right to me. At the very least I would ring the number on the discharge paperwork you'll have been given, and check with them whether this abdominal pain should be followed up.
Thanks Mike. Yep, I'm taking the paperwork with me to the workshop and I'll phone them this morning. Last night was better but still not right, and I still have a worse discomfort than normal.
