Oak Sleeper Raised Beds
BigMonka
Yorkshire & Charente
Hi all,
I'm looking to build some raised beds for the veg in the garden to replace the flimsy ones I did 12 years ago. I want something that looks quite solid and structural so was thinking of using oak sleepers as, despite the painful cost, they will hopefully last as long as might want them. There's a local place that does 240cm x 20cm x 10cm ones which means that three would nicely replace each 2.4m x 1.2m bed (outer dimensions).
I was looking for a way to make the corners look decent and be quite strong so I was thinking of doing half-lap corners with a vertical peg. Like the sketchup model below.
Is this likely to work and look alright? Should I glue the corners as well?
Any advice appreciated!
I don’t imagine they would need gluing as well.
If you fancy doing something different with those corners though how about the half dovetail notch?
This has been in situ now now for nearly six years, no screws, no pegs no glue.
there is a tutorial on how do them here
After the first one really not that difficult.
Is oak really necessary. There's softwood option from sawmills round here. They must be cheaper.
Good question Malc. Our local place has oak sleepers at £37.50 and a softwood "Pressure treated with Eco-Friendly Tanalith wood preserver" at £21. So yes, they're notably cheaper than oak but with them being in constant contact with soil on two sides I wasn't sure of the longevity of the softwood ones?
Oak used to create raised beds will only last well if you treat it and also create an impermeable layer if soil is against it. Wet soil used for growing mediums rots oak more quickly than you might think. This is based on experience of building oak sleeper retaining walls at current house 8 years ago.
Reclaimed railway sleepers (usually soaked in tar) will last a long time, but must be lined to prevent soil contamination.
I made 2 foot high planter beds from pressure treated 2 x 4s and treated plywood. I lined them with the dimpled plastic membrane used against foundations here to facilitate drainage. Works well in the planters by allowing any water to drain away.
probably not useful as you are 'up north' but on my last trip to Yandles they were selling off 2m oak sleepers at under half the price of 2.4m ones - apparently everyone works to a spec. of 2.4m so they up the price on those - no-one wants slightly shorter, so they drop the price on the wood that can't make 2.4m. I do get a discount there as well, with that we were paying low teens for each 2m sleeper... (filled the car - luckily a very hefty payload in the back with air suspension or I am not sure we would have made it home!)
Perhaps worth seeing if your local supplier has a similar approach to pricing?
The " pressure treated" joists I put down for decking had rotted through in less than two years despite being suspended on metal brackets.
The outdoor equipment that has lasted however was steeped in old engine oil.
I was apprehensive about using it at first but allowed to dry first it doesn't smell and doesn't come off on your hands ,so with a liner I wouldn't hesitate to use it on a raised bed project.
Wonder if you had a bad batch of PT.
I made a raised bed using old PT deck joists and still no rot after 8 years.
I did re-coat the boards which are in the ground with a preservative.
I’ve witnessed pressure treated timber rot in under 10 years, also seen insect attack it.
Makes you wonder if is snake oil.
Old engine oil just keep working!
I think in my situation the land drains very well and never any pooling of water where the timber rests.
Now there is a Pt timber rated for below grade use and have used it a few times. I doubt I will never know how it weathers over time.
There is very little good timber available in these parts.
Any paint or preservative that allows you to rinse the brush in water is an instant red flag for outdoor use - and its still a pollutant ,for all its uselessness!
