SIP tablesaw 01332/01446 owners, help please
DBT85
Pershore, Midlands
I have attempted to solicit help...elsewhere but I know a few of you have moved to pastures new.
Anyway. Long story short. I have an older 01446 tablesaw, they revised some parts internally and now things don't line up like they should since I ordered a new motor mount. If you have one that's not 10 years old, can you take this pic for me and post it ideally with the date you got yours new.
The square nub on the top motor mount there used to be on the left of the part, now its on the right. That means things don't line up to connect to the worm gear because they also moved/revised something else, having seen an itech 01332 I think I know what they did, but more pics is more betterer to go back to SIP with and say "see, your diagrams are wrong".
Thanks!
That's disturbing Darren.
I can't help as my 01332 is well over 10 years old so will be old style as well. I had to replace the worm gear on mine quite a few years ago and they had changed the handle fitting but didn't know about that until I pointed it out and had to modify mine rather than buy a new one.
The tech guys are generally OK but the company just buys the machines in like everyone else and I guess they can't know everything.
I don't mind that it was revised as that's just sensible if improvements can be made, but if you look at the technical drawing for the new parts they literally cannot go back together how they show it which means it hasn't kept up with the revisions and makes buying parts correctly difficult.
I've been in conversation with Mike Bott at SIP talking about the saw for a few months and he has been very helpful, but sadly they don't have a saw built there to look at and confirm my suspicions and I don't think anyone that sells them will have one in a showroom as they are likely delivered direct from the main warehouse like most large items.
Apparently they did (do?) have a kit to convert the older 01332s to the new system, but he couldn't find anything on the 01446 and the parts aren't quite the same I don't think. Not that I can tell without a modern photo or correct TDs!
I do have a solution that I think will work should I not be able to find the correct parts, but naturally I'd rather a 4hp 12" spinning blade was entirely stock rather than modified around the business end!
