Got fed up continually running to and fro replacing the 12v SLA battery that provided the power for the electric fence. So went the solar panel route.
After the abortive affair with the small solar panels from C³ I went the whole hog and got a 100W panel and, after advice from Bob, a small solar controller. So bit if metal bashing today.
I discovered a steel and aluminium stockholder in Carlisle and bought some aluminium angle 5m for £28 which struck me as a good deal. One thing I needed to consider was the angle of the panel because up here in the Twilight Zone one needs as much light as one can get. This handy calculator gave me the right angle depending on month.
Hence the holes along the bottom here and two different mounting points on the panel.
A wee box to keep the electrickery stuff in the dry. Exterior Medite covered in linseed oil. Bricks to keep it off the ground.
And a scruffy over-No-Nailed cover
That's it. Simple.
That's it. Simple.
