Accipiter
- Joined
- Oct 16, 2025
- Messages
- 855
- Reaction score
- 636
- Location
- Frome, Somerset
- Name
- Frank
- LOCATION
- Somerset
Some may remember my posting of replacing the 15 pane porch door for a half glazed wood panelled door I'd got many years ago...
Well, the door from the front room to the kitchen, 6 panelled door, splintered at the catch sight on the face, piece lost over time so didn't get get glued back. It was small and probably wouldn't have stayed in place anyway...
So, as I'd not cut up the old 15 pane door I considered using it to replace the kitchen/living room one. LOML wasn't sure so it had to be held in place to get an idea... response was
. So... it needed trimming to size, old hinge placements patched and sanded.
In measuring up it became obvious that the frame isn't square... why would I have expected it to be, being a property built sometime around 1796! I don't know why I didn't realise from replacing the door around 37~38 years ago... Anyway, now I'm aware of it, how to try and get the correct angles... *lightbulb moment* - pieces of cardboard, piece of thin timber, pencil - cardboard to floor (bottom left corner), put towards door frame, thin timber against frame, pencil line = angle. Same with top righthand corner = angle.
Mark up, cut with plunge saw...
there're correct
... (Apologies... didn't take any of the plunge saw work...
The catch is something else for attention once temporarily hung to get the right placement. I'm hoping any patching can be hidden with the handle plates...
End part 1.
End part 1.
