8mm bolts that will rust !
Yesterday our 20 year old ancient elm door to the walled garden sheared all four screws holding the hinge post to the wall. While re-fixing it, I decided to replace the bottom board (ledge-and-brace) but this needs 3 x 8mm bolts (50 or 60mm long) and nuts . All the ones I have are zinc or coated with something to stop them rusting but I want them to rust to blend in. So what should I search for on eBay?
I'm also after four good old fashioned slotted 12 x 3" steel screws as all mine are too short. At the moment, the hinge post is secured with Spax and they don't really 'go'.
TIA
TrimTheKing":32cvxivs said:
Can you not sand off the passivation just on the faces?
That's an awful lot of work, Mark...and very fiddly not to mention sanding off my fingertips!
In my experience the zinc coating doesn't last long - paint them with rust coloured paint or all of them black? :)
I've got a load of old screws- I'll have a look, but didn't use 12's very much?
Unplated is usually referred to as 'self colour' so search for self colour bolts. Having had a quick look it seems a lot of ebay sellers think chemi black is self colour so you'll find a lot of socket cap screws as well with that search.
Thanks for all the suggestions, guys. Will report back.
If you want your metal fixings to blend in, and you definately have to use M8 bolts, then how about brass? It'll be a bit shiny at first but will soon dull down after the first winter, or you can dull them down with an alkaline solution before fitting. And the great thing about brass fittings, is that they won't rust through and need replacing. If you live near a boatyard, go and have a look down there.
Here's some on ebay: http://www.ebay.co.uk/itm/M3-M4-M5-M6-M ... 43c6f4ffc2
Or you could use old boatbulders copper nails. Plenty of them available on ebay (I've been buying some for a sculpture project).
Cheers :obscene-drinkingcheers:
fred
