The central heating pump had been getting a bit noisy so time for a simple swap out. Screwfix had sent me a voucher so I already had the new pump ready - Grundfos UPS3. Early last week Mrs was out for half a day so good time to get it done. Strip the boiler cupboard out and attempt to turn off the pump valves. One moves a little and will probably turn off, the other one will not budge. Grr drain down needed. It can wait for another time.
Fast forward to thursday night... tidy kitchen before bed... water on top of the bins under the boiler. Strip the cupboard out again and sure enough the valve that moved a little is dripping. I thought maybe turn it a bit and it might settle and stop dripping. bad idea as the drip turned into a spray. rags..tin foil gutter... bucket..go turn off supply to header tank in the loft. drain the system no heating in the morning...sleep.
Friday its gas fire and fan heater and find out where I can get plumbing parts and it turns out no one local has everything. reading reviews on pump valves like you do I discover the ones like the old valves are rubbish. better quality are longer bodied.
looking at the old pipes it is all joiners and no pipe so can't fit longer valves easy
So not just replace re-plumb as well. Getting the old pump out was so awkward with the cabinet top at the same level and a foot from the ceiling.
After a good part of Friday and some cursing
The heating is working better now. It just stays on where it used to drop into low power because the temperature rise was too fast.
I tried to get 'Pegler' pump valves but out of stock for collection everywhere so ended up with 'Perfect Pump Valves' from Toolstation. Have to say they looked very well made. Felt like stainless but may have just been nickel plated brass.
