KitchenBOB
- Joined
- Jan 2, 2026
- Messages
- 6
- Reaction score
- 1
- Name
- Bobby
- LOCATION
- Bedfordshire
Hello,
I would really appreciate some guidance and advice.
Recently had one to many children so had to extend the house and make the most of the space to make additional bedrooms. Problem is lack of internal storage. My wife is a childminder so has lots of children's toys and push chair etc and I am kitchen fitter with lots of expensive tools which I don't like leaving in the van (VW caddy) so store inside but again there isn't enough room for this.
What i am looking to achieve is a large workshop & storeroom. We have and angular shaped boundary with neighbour so was looking to maximise the footing of the workshop. i had a 100mm concrete slab put down with hardcore sand and dpm, and i had the slab made to match the boundary with 800mm all around. in regards to the workshop i will be using often for multiple different projects.
i was going to start the build in the summer 2025 yet not knowing where to start and over complicating myself plus no time meant i delayed. yet i cant delay an further which is why I'm reaching out for advice to get the details nailed down on how to create something which isn't going to destroy my tools, destroy my wife's working equipment and have storage still for gardening tools and Christmas trees etc.
I had taken the idea from a video on youtube where the guy built a garden room and i was going to base my workshop on the same spec, he is building a garden room i am creating a workshop, would this be over the top for that?. Also the guy in the video adds his dpm after so on top of the concrete, as i have dpm under the concrete would i still add another layer above or just lay 100mm insulation straight down with OSB above that. Also he installs windows and uPVC glass doors i wont be doing either (may reconsider a window for natural light) as i will be installing 2 metal doors on the shorter side as entrance to a workshop one side and my wife and general storage on the other (wall straight through the middle). i was going to install the rubber roof as i feel this may require less maintenance, yet need to know how that would work with my angled roof. as for cladding i would just use tounge and groove shiplap, all though i have seen some videos where the shiplap expands and contracts quite a lot. Originally i was going to use black feather edge but the wife think it would look horrid in the garden.
I usually over do everything and perhaps spend way to much then is really required and over think a lot which tends to delay my decisions as well. i will be carrying out all the work my self as i am a confident worker yet building a workshop to last and keep the items inside dry and safe requires some knowledge i don't have.
Any advice would be much appreciated
Thank you,
i have attached an overhead with dimensions to give some type of idea, i also attached the video.
Thank you,
