NickM
As I've mentioned in a few other posts over the last few weeks/months, 2025's big job for me is to make half a dozen chairs to go with the table I finished in the Autumn. I'm currently at the design phase and thought I'd share where I've got to.
The first decision is that I want to do a jointed chair. That's the kind of woodwork I do. I don't have a lathe or the kit/know-how to do pole chairs, windsor chairs etc.
I popped in to Edward Barnsley a few weeks ago to have a look at their completed machine room extension (which is fantastic) and to the chance to pick brains about chairs. I came away a little bit overwhelmed but with lots of food for thought!
I had wondered about having a go at something like this which they make at EB. Custard has also shared some info on this type of chair in the other place.
I think it's a stunning chair. The really interesting feature is that the rear legs are rotated outwards. That gives a lovely shape because the curvature of the legs also gives an attractive splay in the chair back when they are rotated in this way. However, it creates some problems. In particular, the side rails and back rail come into the rear legs from opposite sides rather than at right angles which is what happens in a conventional chair. That does weaken joint the most critical joint a bit and as my chairs will be used every day, I'm worried about that.
Having looked at some other chair designs, I worked out that I could still get a somewhat splayed back by tilting the legs outwards. That adds more angles to the joinery, but I think that's manageable, and it means I can stick with a more conventional design.
This was the first sketch I did to visualise what I was thinking about:
I decided to draw it in CAD to try to get a better feel for what it would look like and, in due course, to help think about how the joinery would work. (I also had my son, a design student at Loughborough, at home over Christmas to help me claw my way up the Fusion 360 learning curve!). This is the first effort:
I quite like it, but feel it perhaps looks a little too utilitarian? This is the current version (minus backbars which I find really hard to do in CAD - I couldn't even manage to avoid having one in the middle which I've read is a bad idea as the sitter's spine is right against it!):
I think this is looking a lot better. I introduced some shape in the front legs, a shaped front rail, a curve in the side profile of the side rails, and a "serpentine" shape to the side rails as viewed from above. The rear legs and crest rail still look a bit clunky in my view, but I think I can finesse that (although it might be easier to do that in real life than in CAD given my limited abilities and the fact that my son is now back at uni!).
I think this design has got some mileage. I'll have a bit more of a play with it, but the next stage will be to make a VERY rough (e.g. nailed together) full size model. The purpose of that will be to check the fundamentals of the dimensions of the design.
After that, I'll have to figure out how to make it...
