StevieB
I have an Axminster CT330 thicknesser, about 5 years old. The knives are held in the cutter head by a gib strip, with 6 bolts that go through both the strip and the knife and into the head itself. Each bolt has a hex recess for a supplied allan key. Of the 12 bolts, only 1 turned. Application of heat (blow torch) released another 9 but I have 2 bolts that will not shift, and the heads are of course made of cheese and round over inside the recess as soon as any force is applied. So a couple of questions:
Is there anything I can do apart from drill these out, which will then mean those bolt holes are useless. If I don't then I cannot change the blades. There is no room to file a slot as the cutter head is recessed into the thicknesser.
I have tried heat and WD40 - is there anything else I can try to release these bolts and perhaps get enough purchase to remove them? They are dome headed so spanners will not work.
Really annoyed at this silliest of designs - I cannot see an obvious way to get the cutter head out either. If anyone else has come across this problem how did you solve it without ruining the machine, skinning your knuckles or throwing an allan key across the workshop in a fit of frustration?!
Steve
Steve
