- Joined
- Jul 21, 2014
- Messages
- 10,414
- Reaction score
- 164
Our house is 92 years old and internal walls are 3" cinder block with lime mortar render and skim coat plaster.
The wall in question is part of our walking pantry and will have been dry and cool (north facing). One wall has had a few coats of white emulsion that has very poor adhesion but no has come the time to spruce things up in there and I've scraped the emulsion off back to bare plaster which is superb condition. I cannot see why it would ever have been re-plastered so it is probably 92 year old plaster.
I've seen MikeG refer to mist coat of emulsion applied to new plaster but is this also the correct way to prepare these mature plaster walls. I want to get this right first time as the wall with have a matrix of spur bracket shelving screwed onto it which considering the friability of the old cinder blocks and lime render will only go up once and be a PITA to repaint after installation.
I've read some suggestions of dilute pva but that will form a skin and the emulsion will slide all over the place on top so I don't rate that as a solution.
So mist coat it or something else?
TIA
TIA
