I've posted on this in the past as it is (for me at least) such a difficult thing to master. However, as ever practice helps. I'm slowly getting better, the measure of this being the amount of planing I have to do afterwards. I've just done a 2' x 6" piece of walnut and ended up with two pieces of just over 3/8" thick from an initial thickness of just under 1". They would have been thicker but I drifted a bit more at one end.
My current technique is to kick off with a normal backsaw, then, once I start hitting the brass back, switch to the Japanese thing which is rip on one side and cross cut on the other. If it goes wrong, it will be with the Jap saw. And now we come to the point: I've found that I seem to get better results with it if I use it double handed and held close-ish to the blade.
The reason for this post is to seek views on what folk think of this approach, particularly with ref to technique with the Jap saw. I'm obviously not doing too badly but is there anything I should be doing as a matter of course in order to improve results?
