Is there such a thing as a "Door Installation Specification" whereby the installers/carpenters need to comply with?
For example an internal door on a metal or wood frame -
- what should the play be when the door is closed?
- What gaps should there be between the door and the frame?
- Gap at the bottom of the door?
When I have installed I would have about a 3mm gap top and sides and maybe 10mm on the bottom for airflow and when closed a maximum of movement of say 2mm.
The forum thoughts?
(my neighbour across the road has some issues)
The forum thoughts?
