Most experts start flattening a board by doing one of the faces. There is of course no reason why you can't start with an edge. That said, the disadvantage is that it offers much less of a reference surface than a face i.e. better to correct an edge from a face than the other way around.
This afternoon I decided to saw the waney edge off some pine I've just had delivered so as to be able to stand the boards on edge under my bench while they dry out. I have no intention of touching any other surface until they are dry enough. It occurred to me that the edge ought to be as near horizontal as possible so that the boards can stand as near vertical as possible in order to stand more or less stably.
Then a light bulb went on and I remembered the small level I have and I laid it on the edge:
It worked as an excellent indicator of where I had to remove wood to get the edge horizontal. Then it was just a matter of planing accordingly. I suspect that this will be of extremely limited use most of the time but maybe in special circumstances such as the ones I've just described, someone could find a use for it.
(The phot is not of the wood in question which was 1 1/2" wide i.e. it's just an illustration.)
