Good evening folks!
Which glue would you all recommend for exterior use which has excellent water resistance and is also a half-decent gap filler?
I've disassembled a raised, fielded panel door (I won't say why at this stage as I'll be doing a WIP thread if by some miracle it doesn't end up as firewood) and sanded off a good layer of treacly woodstain, but in doing so I've obviously thinned a few critical pieces by a smidge, in particular where the panels will be re-fitted into their respective rails. Upon disassembly it appears that these joins never had any glue in them to begin with and were a fairly loose fit. Structurally this didn't matter when it was a door, but it will be re-assembled into something quite different.
I am re-using the rails, but cut down much narrower and in their new application both panel and rail will be bearing a certain amount of weight, so the bond will need to be a rock-solid one. The gappiness I mentioned is not excessive, so I don't need something which froths up like shaving foam, just something which will give a firm bond in a gap of perhaps three quarters of a mm at most.
Thanks chaps
Tim
Thanks chaps
Tim
