Hi All
After another long hiatus (mostly down to the birth of our second daughter) I’ve made a bit more progress on the workshop so thought I’d post what will probably the last update for this year!!
My first job since the last forum post was to make, paint and install the facias and sofits. The facias were made from some treated timber I had lying around from the build. I planned them down, glued them up and then attached a lip to the inside bottom edge so that the soffit has something to sit on. Fitting them by myself proved a challenge but manageable with the aid of a supporting arm that I screwed to a rafter near to one end that acted like a second pair of hands - see below pic.
After a test fit I gave them a few coats of paint and put them up.
The soffit’s are currently 11mm OSB that I also had lying around. These are just temporary so that I can get the building closed up for the winter and fit the insulation into the roof. Once I have some cash in the spring I’ll get them swapped out for proper PVC soffits.
I then installed the dry verge which happily turned out to be a pretty straightforward task. The roof is now finished, which is a nice milestone to hit and I’m pretty happy with the results given that it was my biggest worry going into the build, mostly because of all the unknowns around having never touched a roof before.
The inflight task right now is the installation of the window. My naivety showed through a bit here as I was surprised when the frame turned up without the double glazing units pre-installed
God bless YouTube as I now have a pretty good idea of how to install them. So as it stands right now the frame is in and I’ll hopefully have the units in before Christmas which will make the building nice and watertight.
Money and time permitting I’m hoping to get the guttering done over Christmas so that I can begin work on the inside from January. More updates to follow at my usual, leisurely pace
I may also use some downtime over Christmas to compile my first lessons learnt post to cover the external build. I appreciate my updates aren’t as detailed as some on here so I think there are a couple of nuggets of information that I’ve not talked about before that I can pass on.
Have a great Christmas.
Hully
