Marking Gauge?
TBH I think that the wood being marked can be just as much a factor as the type of gauge.
I mostly use Veritas gauges but I do know that when going along pine - as per yesterday - the grain is the bigger thing and it means that whatever gauge I use, marking lightly at first and then more heavily is key. That is less so with hardwoods like e.g. cherry or maple.
I find it somehow more satisfying to use a pin gauge but that requires getting the hang of it, so when in doubt I opt for the Veritas wheel gauge.
Just to resurrect this marking gauge thread, I’ve recently started using gauges and have pin, cutting, and wheel gauges. Only used in softwood so far. I find the wheel gauge much easier to use particularly across grain. Would sharpening the pin or cutter close the gap?
I have the Narex wheel gauge from WH. I like it very much so far, but have no experience of others to compare against. Unlike other brands, the stem is offset in the fence. It has measurements on the stem, but they’re too small and faint for me to read so might as well not be there. Could be useful in a pinch I guess.
A sharp knife works well, just make sure it’s at 90deg or it will pull the cut off line.
I test mine by holding a 150mm ruler to the face of the knife it shows up any error.
