I'd go with Steve but why use cheap bricks I always thought the ones "underground" had to be durable, engineering types?
Mike G":197796bh said:Y
Bob..... the timber frame supports the roof ...
9fingers":3vem9mbr said:Are you fitting an air intake for a woodburner to save burning pre-warmed air.
If you have not thought of this, it is well worth putting in at this stage.
9fingers":mke4e7iu said:Are you fitting an air intake for a woodburner to save burning pre-warmed air.
RogerS":1i81145g said:......Mike..pardon me for asking but I'm surprised that you are having a fire. Surely that creates lots of draughts etc/ heat loss etc?
RogerS":3dwl0x71 said:9fingers":3dwl0x71 said:Are you fitting an air intake for a woodburner to save burning pre-warmed air.
I think it's the Dutch who have twin concentric flues where they draw down air to feed the fire from the top of the flue and so it's already been warmed by the hot air going up the inner flue.
StevieB":3jkb5jga said:I will be interested to see how you manage the foundations you mention on the existing build - 6 inches is not a lot of space to work in!
Steve
Frank":25f4n4jr said:Best of luck with your concrete pour Mike, from the looks of the up coming weather you will need some luck......
Frank
Rod":18szctdw said:Good luck especially doing building work this time of year.
Mike":2dzbmr0y said:
RogerS":1tvrza4t said:Mike, your nifty sand levelling jig. Is it a scraping motion or a tamping motion that you use? Presumably you need three people. One at each end and one person end on to watch the spirit level bubble? Those bubbles are very small...just wondered how easy it was ?
Mike G":38unvmfj said:A patch on both sides is a great repair.
Mike G":38unvmfj said:Don't worry. Nor worry about water in the "pond". The concrete will push the water out. The worst that can happen is a film of water on top of your finished concrete, and you can soon push that off with a broom before the concrete sets. The concrete is so much heavier than water that the water always floats to the surface, immediately, and will get pushed away as you tamp. It doesn't mix with your concrete, unless you allow it to stay on the surface after you finish tamping.
Mike G":38unvmfj said:As for tamping with the DPM in place..........well, it's standard practise, and I have never heard of damage to the plastic. I shall be doing just that myself, although obviously you do take care. A bigger deal with this situation is that the folds in the plastic around corners become very hard and prominent when the concrete has pushed everything tightly to the formwork, and that can make finding the top of the formwork a bit awkward when you are tamping.
Talking of tamping: prepare your tamper beforehand, put some handles on it, and make sure you have another person there to help at the appropriate time.
Have fun with the pour! Do a last check on your formwork.....make sure it is strong enough to resist bowing under the pressure of many tons of liquid.
Mike G":1mh00ggv said:
Mike G":enk7c080 said:It wasn't the water on top of the DPM which I bailed, particularly, it was the 9 inches of water in the trenches which was at the same level as the water under the DPM. In places the DPM was floating. Reducing the general level of water within the excavation was my aim, and, having had a look this morning, I am going to be OK for concrete in a couple of hours time.
Robert":vnz8sadf said:Just thinking... I don't think I've ever seen a brand new scaffold board before![]()
RogerS":71frmc5h said:Well done, Mike. You must be dead chuffed. Time for several beers, I think.
:eusa-clap: :eusa-clap:
