We have a 4.7m steel spanning where the sliding doors will go. There is an inside steel that supports the joists and sits on top of masonry piers etc. There is also an outer steel that will take the sandstone lintel as part of the surround.
To maximise the amount of sandstone visible outside on the jambs, the builder was suggesting overlapping the steels..ie locating the inner steel inside the outer one so that the outer steel can slide further back towards the inside of the house. This would mean that the doors would sit further back in and so reveal more of the jambs.
I've resisted this saying that that will effectively cold-bridge along the span, condensation on the inside wall and heat loss. Is that a fair comment ? Gut feel suggests that the two steels should not be touching.
What else though to minimise heatloss there? Bung some Kingspan in between them? Where the arrow is.
