Motor capacitor
Lurker
Loughborough
Are they go/no go?
Table saw motor stalled from starting a few times this morning, nothing is tight so it’s not seizing.
When the saw runs, it’s as normal.
They can change in value going low and causing the motor to loose power.
I bave a component tester I can test it for you, I have a box of exotic wood for you from Steve m I could test it for you when you come to pick it up.
I think I will have a rootle and check the value of the cap, and it’s connections. A spare won’t be a bad idea anyway.
I must make an effort to get up to see you, how are you getting on, by the way?
I am getting on much better, I managed to put on a pair of pants on standing up, when you can’t bend your knee simple things can be so difficult.
You are welcome to pop round any time, I might be back at work next month.
This is what is on the motor.
I am visiting Pete this week,for him to check it out physically it looks ok, beyond that I am out of my depth.
Cabinetman":177srsve said:
Bit late to mention it sorry, but even new ones can give a belt if not shorted across the terminals with a screwdriver.
Strictly speaking, a low-value resistor (or a high value resistor for a long time) is a better option as there's less chance of damaging the capacitor from the high currents involved in shorting it out. In most cases you'll probably be fine with a screwdriver though :D
When I was around 20 I was repairing an ultra centrifuge and I forgot about discharging the capacitors, I woke up at the other end of the lab.
Never made the same mistake again :D
Cabinetman":lixiwvoe said:
Sorry Lurker, I was obviously preaching to the converted.
It was good information for anyone who might stumble across this thread at a later date.
