Much needed smaller sliding compound miter saw.
duke
Field, Ontario, Canada
Scott
Over the years my 12" saw was a chore to get to upper levels for home renos, so this is much needed and will save me endless trips outside to make cuts. I don't make purchases on a whim so no regrets. Tried it out in the shop and works fine.
The scale/size of it became apparent with your hand on it, handy for most cuts and I know what you mean about traipsing up and down stairs for each cut, last week with a flooring repair and all this week installing the insulation above the workshop, gets to be really annoying after a while.
Can’t fault you getting a smaller cordless saw Scott I did the same about six years ago, my shop chop saw was just too heavy to keep lugging around as I got older so I bought a cordless Metabo 8” sliding compound miter saw, not quite as accurate as the Kapex but more than good enough for site work & a lot easier on my back.
Scot I was about to do something similar to you but then I bent the arbor on my DW708 (a big beast) and couldn’t find a arbour replacement, so I bought a small Kapex. It’s lightweight enough to take to site and only two screws to hold it in place in the shed.
I do have a little Elu chop saw from my time in the uk but that’s 110v and that was a right royal pain in Europe, everyone would ask about the heavy yellow transformer and I could see there thoughts…..crazy Englishman 🤣
How did you manage to bend the arbor? Once I had to take my 12" with wheeled frame/stand down a slight uneven slope and off it went flipped over but no damage thankfully.
I also bought a lightweight Titan sliding mitre saw for £99.99 from Screwfix. It's adequate for it's purpose. However eyebrows were raised to read this on the Troubleshooting chart...
Problem - Product does not start
Possible cause - Not connected to power supply
Solution - Connect to power supply
They walk among us.
Cutting up an odd shaped piece of Olive wood, it jammed up and then…..BANG! should never be done on a cross cut saw, I was being creative.
This is my stash of Olive
