My first veneering
Stuart
I’ve always admired well veneered work but have generally considered it outside the scope of my skills/equipment and so avoided it.
However, in my desire to use timber that would otherwise prove to be rather expensive (and wasteful if it goes wrong) and add to my skill level I thought it time to have a go!
Plenty of reading and watching videos as well as some encouragement from a chap on a Facebook group lead to the purchase of some elm and zebrano.
I had a few plywood boxes knocked up for various projects and thought one of those would make an ideal first project. I’ve kept it simple and it was basically pva and parcel taped cauls together with some careful trimming and light sanding.
I did have a monemt of panic after I’d glued the ends on:
Lots of squeeze out (despite being careful with the glue) and what appeared to be grey blotches. Careful scraping removed the glue but the blotches have been very stubborn. It was nearly a bin it moment but I persevered just for the hell of it and even if I say so myself the finished product (just shellac and wax) isn’t too bad. The boss liked it enough to insist it was lined.
You can still the grey blotches, no idea what they are or what caused them.
Not the biggest veneered project ever undertaken but very useful for me to learn a bit more.
Due to using an already assembled box I didn’t use a balancing veneer and appear to have got away with it (I suspect using plywood also helped). I do plan to have a go ‘from scratch’ and veneer panels then make the box but as I’ve still got a couple of pre made boxes I do have some fiendish plans …….
Never mind the veneering, the anti-gravity box and desk is quite a spectacular achievement! :)
I gave up using wafer thin commercial veneer some time ago, though I still have a bit in the 'shop (several thick 'books' of teak and mahogany) and use it only when I really must. It's difficult stuff to use and join so I now make my own 2mm veneers using the bandsaw and drum sander.
The grey patches in your box are probably glue 'bleed through' if you used a PVA or equivalent. You'll only be able to lightly scrape and sand commercial veneer; if you go at it with a bit of gusto, you'll go straight through it quicker than you can say 'rounded bevel' :lol: - Rob
I really like the way that you have hidden the joint between box and lid so well.
And thanks for another idea for a small scale project.
Cabinetman":uzrmn6e7 said:
Well it looks good to me, but it is a shame about the marks. What sort of glue did you use?
Bog standard titebond Ian.
It was clamped for 24 hours between parcel tape covered plywood so I’m wondering if the inability for moisture to evaporate quickly enough was an issue?
I’ve also veneered another similar sized box (in elm) the same way and there’s a similar (but smaller) blotch on the end of that as well.
Nothing on the sides or top and they glued the same way.
It looks good Stuart.
It may be worth giving Titebond Cold Press Veneer glue a try as it is less prone to bleed through.
I also put a piece of paper between the piece and the board being used to flatten it to absorb any moisture.
