StevieB
We have recently had out hallway and stairs plastered. Good plasterer, used him for a long time (several houses) and no problem with his work previously. The hall and stairs are big - was a 5 day job to do a skim over the original horsehair plaster. All onto brick walls underneath rather than laths. Only problem with it was it required approx 3 coats of 4:1 PVA to prevent he plaster drying out too fast for him to work it properly.
Plastering was finished approx 4 weeks ago and since it was done large hairline cracks have begun appearing. By large I mean long rather than wide, not enough to fill properly but enough they will show when painted. Is this something others have come across? Only explanations I can come up with are too large an area so something has to give as it dries and therefore cracks, or it dried to quickly and therefore cracked as a consequence. From application to dry was typically 24-48 hours, which is fast. Usually it takes 3-5 days for a room to dry. There is certainly no movement in the brick walls, they have just been skimmed. I did try to take a pic but the cracks are not really visible in the photo. I haven't started painting yet but hope to in a couple of weeks time.
Questions then - what is the best way to fill these - simply polyfiller or some other method? And is this to be expected and if so anyone know why it has happened?
Cheers,
Steve
Cheers,
Steve
