I've just been offered this, or at least 2/3rds of it as a potential workshop, the other third will be used by the owner to store a couple of classic cars. Its an original Nissen Hut, in stable if not good condition, dry and cheap!
There are a few little holes around the bases that need filling and what looks like a condor's nest in part of the roof but nothing that can't be sorted out in an afternoon.
It will need to be made a little more secure but its remote location helps, plus there are a couple of guys who live on site nearby
The downside is that its not insulated, just the inner and outer skins of wriggly tin and no one knows whether the slab has any membrane under it although I'm told it is always dry. There is power to it but not sockets, lights etc as yet.Its 12.8m x 4.8m but its going to be very expensive to try to keep that heated during the winter months and I'll only use it at weekends until I retire in 5-7 years time.
So I thought I might be able to build a workshop inside, say 3.5m x 4m x 2.4m, that would be insulated and heated (as if is was outside) to keep tools from rusting and to give me somewhere warm to work in. The extra storage is what appeals to me. I'd install windows to steal some light from the rear windows of the hut and back it up with LEDS.
The question is do I need to raise any wooden structure off the floor or would it be safe to lay it straight onto the floor with a membrane between concrete and floor. I was thinking a 50x50 framing floor with 50mm polystyrene insulation inbetween and 18mm flooring. Then build a 75x50 frame with 12mm ply internal walls, 75mm insluation and just a membrane on the outside to hold it in and keep the bugs out. 175 x 50 roof joists, 100mm insulation and 12mm ply ceiling, again with just membrane on top. Would I need to clad the outside? seems overkill as its not going to see any weather but would the lack of cladding reduce the effect of the insulation to any significant degree?
I'd have a saw bench outside the shed and no heavy duty machinery
Am I missing any obvious problems doing it like this? Is there a better solution?
It does mean I can reduce the size of the shed I'm putting in the back garden at home, that can be just a normal garden shed size now
