Seven Heirlooms - Polished to a high gloss!
@Malc2098 :
I wonder if you expect to be able to discern a difference in tonal quality of each instrument given the different wood species used ?
And to what extent, or even if its perceivable, does the pore filling and selection of final finishing media have on final tone ?
Is it known whether the refinishing of older instruments changes the tone significantly ?
I know very little about the tonal crafting of acoustic instruments but even after years of hearing abuse around Jet engines and loud equipment I can still discern a difference in the mellow blending and purer tones emanating from the output of some of the renowned luthiers when showcased.
Sycamore has become one of my favourite woods after making the bench and the recent drawer box. It really is beautiful and those instruments (including the pine one) look lovely.
@Malc2098 :
That's out of my pay scale, I'm afraid. I would be surprised if there's much tonal difference between finishes of instruments as small as these, as they are generally strummed. But, a bowed violin, could sound different with different finishes.
However, I think the choice of timber, and its thickness and its bracing would all have a contribution to its sound.
  • Like
Reactions: CHJ
I've heard about in the olden days the old cabinet makers used shark skin to finish wood before varnish, but following a violin luthier's channel, I found out about using glass.
Sorry about the rubbish focus, but you can see I'm using a glove on one hand to wipe away the shavings.
I'm not going to tell you about how to create the scraping pieces from 2mm glass, I'm just a humble beginner with no experience except today.
But, by golly it works for me.
Next skill, mastering cutting curved contours in glass to match profiles requiring scraping. 😈
Actually, they get quite close to it.
But, I can scape a compound curve with a straight edge, and they show scraping with a non-exact curve, convex and concave.
OK. All seven necks and all seven bodies have been pore filled with one coat of finishing epoxy and scraped back to wood.
All that is left to fill on the bodies are the rosettes, the Padauk has quite an open grain. They're curing overnight.
After that I will have start shaping the bone saddles and nuts.
Now all the pores are filled, even on the rosettes, and scrpped and sanded back to wood, I can do no more to the necks and bodies till the outdoor temperature reaches and exceeds room temperature, when I can spray them with nitrocellulose clear gloss. Till then they stay hung up out of the way in the workshop.
But I still have little things to do like shaping the bone saddles and nuts. So I'll start with the saddles.
I buy the bone blanks at 3mm thick. I have already milled the bridges with a 3mm slot for the saddle.
I cut the blank to length, give it a slight sanding on both sides so it fits without forcing and then round the ends over to fit the slot.
Then, having picked up this tip on the luthier course I took some years ago, I use the little U shaped slots in the top of a Stanley blade to shape the top of the saddle round, the bit that the strings go over.
The black marks you can see are the remains of black Sharpie so that as I wear away the bone, I can see to keep the wear even and should leave a tiny black line along the middle.
After a little fettling with a fine file, it slots in a treat.
It's quite high at the moment, and I shall leave it like that till after the bridges have been glued to the bodies and the instruments assembled and strung, then I can file/sand away the bottom till I get to the correct height.
I may not have mentioned before, but each of these instruments will be fitted with a piezo under-saddle pickup, so the fitting has to be spot on so the vibrations can travel through the bone to the pickup with no gaps.
One down, six more to go.
Blimey, Malcolm, this really is astonishing stuff. I'm so very impressed.
I'm also seriously impressed with my ignorance, because I recognise almost none of the terms you use for the various parts.
Thanks, @Mike G . It's a language I've had to learn, too, a bit like the component parts of table.
How do you cut the bone to length Malc? Is it a hacksaw job?
Actually, no, @NickM . I make a face side and edge pencil mark on the bone balance at the correct length, place it in the jaws of the vice and use the vertical side of the jaws to guide my Atsuba saw through the cut. (At the end of the project I'll replace the blade.)
You're going to love this next bit! To reduce thickness to the size of the gap on the instrument neck, I use a shooting board and my jack plane. Then to to get final thickness, I have an old shooting plane with the gubbins taken out and the sole covered in self adhesive abrasive. I just give it a few strokes on the shooting board till it fits nicely in the neck.
That’s as much as I can do to them for now. Just got to wait until about July when the weather is warm enough to spray them.
Time to get the notebook out and plan the next season.
Time then to get the laptop out and CAD design the chosen projects.
Time then to get the CNC machine out of the rafters and start machining.
The waiting for better weather must drive you nuts , it would for me.;)
OK, I know I said I was going to take some time off from instrument making, but while I had the CNC down from the rafters I decided to include the 'spare' instrument for my great niece and milled the letters out of MoP and their pockets on the headstock. I'll glue them in tomorrow and it'll go back up on the hook waiting with the others for the warmer weather to to be able to spray them.
Clever and so very effective.
Did you ever decide on cases, hard or soft, for these heirlooms?
Thanks, Andy. I've ordered, and paid for, 7 hard soft cases (or they could be soft hard cases). The supplier has sent 3, but now has no date fro availability of the remainder. They're still shown available online, but with no delivery date. Grrr.
Been a while. The hard cases arrived eventually, and now we've got a spell of warm dry weather. So it's up with the dust sheets round the verandah to create the spray booth.
Already the grain, especially the Sycamore, is beginning to pop.
I've acquired a Fuji MiniMite 4, used, from FBMP, and as an amateur, I found it much simpler to achieve a decent finish so far on the instruments. It's HVLP (high volume low pressure) and it's much more controllable, for me at any rate, then a LVHP compressor powered spray system.
as much as I know you have enjoyed doing them will it be a relief to see them finished? I note it has been two years now.
Yes, you're right, Andy. It's been a while, but it's worth it. They're all our grandchildren and my great niece, and it'll be nice in years to come when one of them might say to their children 'My Grandad Malc made this, so learn to play it, look after it and then hand it down to your children'.
Didn't anyone notice the foam earplugs in the tuner holes on the necks? They're there to prevent lacquer build up on the edge of the tuner holes which takes an age to remove to get them to fit properly.
They're a doddle to fit; just gently roll them between your finger and thumb and they reduce in size such that you can fit them in the holes. Then they expand to fill the holes completely.
@Malc2098 any progress? what finish did you use? these are looking great so far.
Thanks, Ben. I'm slowly working through the spraying and rubbing back process through 2 coats one day, rubbing back the next till I get 8 coats and one more rubbing back before I'll let them rest and cure for a couple of weeks. After that, I'll hand wet'n'dry micro mesh the finish up to 12000. Finally, I'll fit the bridge, saddle and nut before fitting the necks to the bodies and stringing the instruments.
During this dry spell I created a temporary spray booth on the deck outside the workshop, and each part of every instrument has had, I lost count of, about 10 or 12 coats of lacquer.
That lacquer needs to be flattened with abrasive and these photos show what it's like after 600 grit.
They're all flattened to 600 grit now and I'll let them cure over the next two to three weeks.
They look matt now because it the lacquer surface is now flat, but I will wet 'n' dry them further with micro mesh from 1000 grit all the way to 12,000 grit when it will finish as a high gloss.
That Sycamore is just going to pop under the high gloss.
So that will take me a while. :)
And while I'm waiting for all the components' lacquer to cure, I've ripped up the last of @NickM's corner offcuts of his beautiful Sycamore dining table.
Please excuse the bandsaw marks, but I think you can see that next season's two little Soprano Ukulele are going to have some stunning figure on their backs and sides.
They will be for sale if anyone is interested.
At first glance I thought you were make paper Sycamore aeroplanes!
Three necks rubbed back to 12000 micromesh.
This is the third of the Sycamore necks. Their grain just pops!
Maybe I've been a bit naive, but I was always under the impression that micro-mesh should be used wet on lacquer, like using wet 'n' dry up to 1200 grit. Have never been really satisfied with the finish up to 12000.
Today, by chance I used the micro-mesh dry on the narrow side of the headstock and after a couple of passes noted how smooth it was.
So, I went back to the headstock on the first neck and rubbed back dry all the way through from 1500 to 12000. The results was amazing. Not perfect, because probably my prep up to 1500 was maybe not as thorough as it could have been. But the mirror like finish, even with a few blemishes underneath, was so much better than I had achieved before.
Maybe you spinners who use micro-mesh knew that already. :)
