There's going to be six 4 or 5mm Bubinga shelves Andy (already cut) which gives SWIMBO plenty of room for all her nick-nacks, but they're all of varying sizes, so she's got plenty of different options for arranging the distance between the shelves.Very nice Rob. Why so many holes? Obviously for shelf pins but that allows for an awful lot of adjustment
You're telling me it was risky! I had to plan out what I had to do very carefully so the 'set up' took ages before I even switched on the router. The job was deliberately equidistant from the ends of the plank, so I stuck a piece(s) of masking tape on the ci surface so that when the end of the pine was level with them after a pass, the cutter was approx 10mm away from the top or bottom. You can see the two pieces of tape on the second pic.That was a fairly risky fix there Rob, but I reckon you could have gone nearer the ends.
No I wouldn’t have either lol.
Have I missed how you got those nicely polished chamfers around the pin holes?
Chamfers around the holes were made by using a countersink bit as a way of disguising the tear out on the edges as I stupidly used a 'James Blunt' drill bit - Rob
