Having been in the new place for a fortnight, we've decided that it needs a lot more work doing. First up is to rip off the plasterboard on all the external walls, insert Kingspan between the studs, replace the plasterboard and skim.
We also want to replace the radiators with a more modern style and so need to do heat loss calculations. Most online systems only give a few types of outside wall - brick cavity, brick cavity with insulation, solid brick, timber frame - but none of these fit our type of wall which is probably 200mm stone, maybe a cavity then thermalite blocks. If you look at this picture, you'll see that they paid lip-service to any extra insulation and so our plan is to put Kingspan in between those studs - 100mm thick or thicker if I can squeeze it in.
So my question is does the u-value of this proposal match or come close to any of the u-values used in the online calculators (brick cavity etc) ? I tried Googling but couldn't find any sensible answer. Or at least one that I could understand !
Also not sure but does one need to use foil-backed plasterboard ?
As an aside, the reason why I opened up these panels was to see if there was an original fireplace behind. Up in the loft space there are four original Georgian bedroom fireplaces and it would have been great to find a ground floor one.
My surveyor was round the other day and we investigated a bit more and delighted to find that there is a flue behind those thermalite blocks and so he's planning to come along with a borescope.
