What I have fixed today
On the 7th May I retrieved a large Bonsai pot from the local recycling centre. Checking it over showed a crack running down in one corner and then splitting across two sides lower down.
View attachment 55457 View attachment 55458 View attachment 55459
After a good clean to remove the old grime I used some 'super glue' into the cracks and left until this Wednesday gone, 17th June, when I got out a 'dremel' type machine to follow and deepen along the crack lines. Sorry, no photos of that stage.
I then mixed up some epoxy resin to run into the now 'grooved' cracks and dusted over with a false gold dust... a process based on a Japanese method known as 'Kintsugi': https://en.wikipedia.org/wiki/Kintsugi
View attachment 55460 View attachment 55461 View attachment 55462 View attachment 55463 View attachment 55464
Using epoxy resin (Araldite type) is certainly a whole lot quicker - and less expensive - than true Kintsugi. Quick mix of epoxy and either add the 'gold' dust - or some coloured powder of choice - or brush on as the epoxy is going off. In the past I've mixed it in but this time just brushed over.
Yesterday I repot one of my (Yamadori) English yew trees as this reclaimed pot is deeper than the one it was in. This tree suffered from root rot with the wet winter we had in my area in 2024. Seems to be gaining health so 'slip potted up'...
Time will tell how long the pot will last but should the frost get into it another attempt at a Kintsugi repair can be done.
Is that a Ginko bonsai I see on the right side of the last pic ?
Yes Scott ☺️. I was lucky to win it in an online bonsai raffle about 5 years ago - along with a Japanese Deshojo maple. The Ginko biloba is around 38" (inc. pot) - or 34" from pot surface. Sorry for the glare, bottom left in the photo... the sun is directly in line with it...20260621_140518.jpg
I'm coming round to your way of thinking Rob... they are time consuming...
Weeding and wiring aside, it's trying to do the repotting of those that need it - against the pressure of weather during those times, pinching back to get smaller leaves and ramification... trimming back - pressures of whether to use those 'trimmings' for cuttings, as well as root cuttings, and propagating those on... airlayers and such. Protecting from the late frosts we seem to get... seem to be fighting against the weather a great deal of the time 😕
I became quite taken with Paul's Scarlet Hawthorn about four years ago. After getting one (grafted stock) I was going to airlayer the long, straight branches - got told they don't airlayer very well nor do cuttings take. I had to find out for myself. Haven't yet tried to airlayer but did try cuttings in 2024 and '25. From '24 I've had 4 successful 'offspring' and from '25 around 10... I'm a glutton for punishment.
Sunday 26th July I will be taking some other 'starter trees' and, possibly, some others I can get in the car, to a 'Bonsai Boot Sale' taking place just outside of Westbury, Wiltshire... 🤞that I reduce what I have and take others in 2027 🤞
I started noticing there was water under my dehumidifier in the workshop. Ahah, I thought. That'll be something wrong with that magnetic switch thingy that turns the machine off when the float reaches the right height.
Was it 'ell as like! I cleaned all round the switch and made sure the float pivoted freely, but the floor was still getting wet.
So I had to get my screwdrivers out. But I should have guessed from the condition of the water container, because it not only contained water, but also a clear gel substance. I had already cleaned all that off before.
I unscrewed the casing and separated the two covers and there all around the exits where the condensed water came out was clear gel stuff and a lot of it mixed with saw dust as well, most of it Padauk coloured. So this all got cleaned out, everything got put back together and I plugged it back in. It seems to work. I can hear whirring, so it was good I didn't pull any wiring connections off.
I'll just have to wait til tomorrow to see if it's leaking again.
That gel stuff; cellulose?
More likely to be a type of mould, seen sometimes in refrigeration units and often a pink colour. It will need to be killed off or it will come back - -sorry. Don’t know the cure, bleach?
It's absolutely clear, no colour at all.
A fix of sorts.
My wife struggled to move a heavy weight I had repurposed as a doorstop, I got fed up listening to whingeing and needed a few brownie points so a length of old chrome pipe, a 10mm long bolt from the bottom countersunk flush and a 3D printed handle and it's all smiles again. I pinned both the handle and bolt into the tube as well as using epoxy.
Typical though what I thought would be an easy drill through cast iron proved to be difficult and I broke 2 drill bits and after the first 30mm it seemed very hard metal. I used a drill press, slow speed and cutting fluid..
This machine had a wadd of cat hair bunged up in the hose, took a while to get it out. While at it removed the motor lid and blew out all the dust.4693.jpg4694.jpg
Cat hair? Wow.
Do you keep a leopard?
Being serious for a sec, having unbunged my late MiL's Dyson several times (both she and her daughters had long hair), it's the only domestic brand I've refused to have in the house.
Thus we've had Henries* for decades: they've been brilliant, and spares are easily sourced and inexpensive. I've also modified my two shop vacs to take the same hoses, which has been really useful.
Got round to starting to trim back the lazy neighbours overgrown and overhanging bush... and brambles...
Next is to trim back some of the Hazel's, yew tree and a Scots pine. Not suitable trees for the small gardens in this location...
Trimmed back the Hazel, which was overhanging the small summer house/retreat I built for SWMBO, in the spring - but strong winds have blown some thin, long branches into the Scots pine so they'll beging to spread over the fence...
Today I came across the vice dog that I had removed as I kept tearing my thumb nail on it, very rarely used it but don’t want to lose it so I made a little pocket for it to live in near the vice.
And for you Europeans who might be wondering about the vice it’s an American made Yost vise very similar to a record, it measures 9” across the top. Works pretty well.
This has to be my ultimate MacGyver job. Didn't have a shallow electrical box so I modified a plumbing part to be the box. Found an old pull type lamp holder and fastened it to the bottom of the fan.
Wife was most impressed but I hope you will paint it black.
Great idea Ian, right close to the vice and not in a drawer or shelf where you might not remember where you put it.
Not exactly 'fixed' but... After trying to recharge my massive Disston that I was using for chainsaw duties I stupidly listened to some YT channels about flattening the blade. Before that I'd just sharpen precisely against the orientation of the teeth. If that makes sense.
Not changing anything about the saw. But, then I decided to remove the breasting (I learnt that after!!) of my £250 or thereabouts, saw. What an idiot. It never cut the same again and I ordered a saw set and put both away for a rainy day.
Yesterday when starting to cut down some lengths to make the base of a cheap bathroom cabinet bottom (under the sink drawers, crap as crap comes but my wife likes em so its fine!!) that we ordered for £300, I decided enough was enough of using my cheap Irwin that I'd bought in the interim.
Pulled out the Marples which was blunt as anything but I didn't fancy continuing to wear out my cheap Irwin on some long rips. So, out came the saw Holder, vice, files, saw set. After a quick check on a few channels and ensuring I don't do something stupid again, I got to work.
Filed the teeth from either side so as not to cause, erm, tracking issues. Before thar I did a very brief grind of the tops of the teeth to bring em all flat (the Marples is not breastfed thankfully). Then got to work with the saw set which didn't really do much as I'm only about 3 or 4 sharpenings in since buying it refurbished (the Disston was an NOS so harder to swallow when I scr*wed it over).
The results... the brown board on the left had an almost square cut that tracked precisely in a straight line. Happy with that and I'll treat myself by making a quick bird feed holder bracket... before getting on with cheap bathroom cabinet/sink duties!!
Sorry, there's alot of info in that pic and I'll get on with repairing the Disston once I've read up more on how to 'breasting' again.
I just looked back at your other thread and the beginning of the sad story of your rip saw.
I'm glad you are trying again with it and have got encouraging results so far.
Incidentally, thinking that £250 was a lot to pay for a saw, I checked the prices from Thomas Flinn, for an equivalent, properly made in Sheffield saw.
While their "Centenary Edition" 28" rip is £240
their Pax branded saw is 'only' £159.79.
Thanks @AndyT thankfully (I just checked) I got my 'new old stock' in excellent condition from Tool Bazaar for the measly sum of only £95. I started looking at replacements from TF after I'd knackered it but then decided >£120 was probably way more than I could afford at the moment (alot going on where money needed elsewhere and my wife would kill me if she found out!! haha).
I think the cheapest i found was about £120, same saw (TF) but from another reseller.
Well... realise I'm stretching it a bit... NOT something I've fixed today - yet - but looking towards future needs?
Shopping at Lidl this morning... £1 off with Lidl Plus... so... £4.99...
I can never find a sharp needle when needed so I'm thinking these will come in handy *when* I get a wood splinter in a finger or hand... So long as I remember where I put them...
In case it's not clear what they are because of the plastic tube sleeves... Tweezers X10..
Mine doesn't 😂... thats why I'm usually trying to find a suitable sharp needle to dig out the darn things
With that many you you can afford to leave a a pair in each room, tool box, overalls etc.
Differing 'heads' (?) Andy... some curved, some pointed, some flat... if I did spread them around in different places I'd most likely not have the one needed and be searching all over the place. Putting the case in a drawer/storage suitably marked on the drawer front - safest 😉
Well you’re a braver man than me! All these years I’ve never spent the time to learn to sharpen a saw so all credit to you, my rationale was that it’s a job best left to experts or Shafiq !
I’m a hard point saw man, wickedly sharp but yes unfortunately throw away after a few months.
Good point Ian. To be honest when I messed up my Disston I really was gutted and felt like a right prat. Especially after having processed x amount of the sycamore tree with it. But am hopefully I'll come out of this stronger.
Problem with hard point is that when I need them, they're blunt and I don't have the money to go buy another (an endless cycle) cos I spent too much on tools/gear in the first place 😆.
Its ripping nicely at the moment (the Marples).
Not fixed today but in 1/2 hr chunks over a few weeks
This had been put out for the gypsies but I spied it first
There was something about it a little different - it was a Rover ,an Australian brand of some repute
It has an aluminium deck rather than the usual rotted- through steel ones,so warranted further investigation.
From experience I know these things are often chucked for good reason so they can be a soul destroying money pit.
The chassis was pretty good but the motor ,a 2006 Briggs 35 classic had no starter rope ,ruined control cables,compost in the fuel tank,no spark,no air filter, no compression , no oil and almost every fixing bodged.
Apart from that it was otherwise pretty good.......
Well being a slight hoarder ( seven mowers,four brushcutters ,three chainsaws,a rotovater and an auger) I have a shed full of bits that might have helped but in the end I decided that any work on the motor was only if I got really bored because hidden away after a previous life I had a 1991 3.5 Briggs Quantum that I know was good.
The deck has fixing points for briggs and honda and the replacement motors output shaft was identical to the old one.However the bolts were different so I had to drill out the motors holes and retap them to suit.
In the years between the engines things have changed with regard to safety and emissions so the controls were incompatible.The dead motor had a primer bulb start, separate throttle and a deadmans handle ignition/engine brake
The replacement had the older arrangement of choke,throttle and ignition cut out all combined on a single lever.
I found a control unit from a late 60s green Hayterette that works really well.
Also found a new air filter element- about time too.
Blowtorched the sparkplug and reset the gap
Finally got it all put together with fresh oil and fuel and it started second pull ( after 15 years upside down in a damp shed.)
It could do with a new pullcord and some new blades sometime down the road but it can earn those first as the whole project has been at a few pennies off zero cost.
Well pleased
God forbid this site ever becomes a woodworking forum but just in case I also made seven beehive crownboards including two perspex ones using 3/8 ply from a 60's table ,sliced up old decking and a panel of 3 mm polycarbonate from a supermarket trolley bay.
Again, pennies.
... and just like that it was brought back into action. Thanks for sharing that @fuse.
My first petrol lawnmower (I think a Mountfield, well used and second hand to me) years ago had a Honda or Briggs engine. I could never figure out (well, I needed a way to get under it, but that wasn't happening with the lqck of workspace I had) how to change/drain the oil without it kinda going all over. I assume there would have been a drain plug underneath but I would always just drain it by sitting on its side.
Never occurred to me to look for an air filter as I just assumed it never had a removable one.
The house we bought recently came with an ERV, an energy recovery ventilator. These have become fairly common in modern houses here that are built to be more air tight. They exchange stale household air for fresh air while retaining about 70-80% of the energy in the conditioned air. Anyway, one is supposed to change the filters on these every three months or so. However, when I open it up the filter was caked solid with dirt and mold and even a few leaves. I think the previous owners had not changed the filters once in 12 years. The heat exchange core was ruined and the model was obsolete so it couldn't be repaired.
Here is what it looked like after I removed the exchange core. The orange filters I bought before I knew the unit was trashed.
We ended up buying a new and somewhat larger model that I installed yesterday. Installation is straightforward: hang it from a French cleat, Connect the ducts, plug it in. A touch screen lets you set the parameters for how much air you want to move on the supply side and separately on the exhaust side. All of that went well. But when I went to adjust the air flow I found that no air would leave the exhaust side. As if the duct was obstructed. Since the ducting is all inside the walls it was a head scratcher to find the problem. Then I finally figured out that the installer, 12 years ago apparently, had connected the exhaust ducts to the wrong ports! The unit had never worked properly at all. After figuring that out, I reconnected the two ducts in their proper locations, and everything now is humming quietly along, exchanging approximately 1/4 of the house air every hour. I don't know if that is too much or too little since there are so many variables that define "sufficient" ventilation, so this is a start. I've also set it to very slightly pressurize the house while it is doing that to keep air infiltration low. It also has a boost mode with a timer so the exchange rate can raised temporarily when needed, like when cooking or when a crowd gathers.
Satisfying to have figured it out.
I don’t really know Gary but that rate of air circulation seems a lot, I’m imagining a howling gale, probably because I’m at Pam’s son’s atm, and the air con is set pretty cold and it’s blowing all through the house like a very bad draught, and I’m perished lol.
One of the few things I dislike over here is that everywhere indoors is cold in the summer, I find myself going outside to warm up, and it’s not just me I am really surprised at how many people are sat in restaurants in coats and jumpers in mid summer!
They're called an MVHR system over here (Mechanical Ventilation with Heat Recovery). They're not common, but I've been installing them in every project I've been involved with over the last 30 years. We work on 1/2 an air change per hour, but even so, it's such a gentle air movement that no-one knows the system is on. No condensation or steamed-up mirrors, even in the middle of the coldest winter. No wet dog smells in the house. A fresh-smelling house when you come back from a 3 week holiday. No mould. And best of all, no trickle vents, and therefore no draughts. Fresh air, but warm. They're a brilliant bit of kit.
Since the ERV became part of the Ontario Building code most people that have these in their homes never use them.
Yes, I can understand why. The beneficial effects are often not obvious. How do you know if COs levels are too high? Or particulates from cooking dinner? It is easy to just ignore them.
There seems to be two philosophical positions on this. One is to add all kinds of sensors for CO2, VOCs, humidity, NOX, particulates, and let the smart system adjust ventilation accordingly. Another is to skip the monitoring and just set it once for an average ventilation and accept that sometimes it will be enough and other times not enough. Perhaps add a timer in the bathroom that will boost ventilation for 30 minutes or so. One thing for sure is that very few people want to spend time staring at their air quality data and manually adjusting the thing. And most people don't change their filters as often as needed. The greenbuildingadvisor.com forums have really good discussions of all the ins and outs of using these things, where they appropriate, payback periods, use in summer vs winter, etc.
Still got my T7, great bit of kit but way too slow for re-grinding 5mm thick, tool steel plane irons - Rob
And we always have the windows open unless it is a heatwave which negates using the ERV/HRV.
As Mike has said it is bennificial in a tight home draft wise.
I had a T7 bought new but I sold it on after a few years as I found it too slow and too messy. Just my personal opinion as I know others love them.
They are great, especially when fitted with a coarse diamond wheel, which I thought, in my stupidity, would 'cure' the slowness issue. It didn't; it just meant that I never had to re-dress the wheel and it always stayed at the same diameter....but it was still bloody slooooooooooow. However, SWIMBO persuaded me to keep it on as I've found to my dismay that it can be, (if the God's decide to pi$$ on your parade) a mistake to get rid - Rob
