Cased frame sliding sashes with hand tools
Planeiron
Co. Down
Co. Down
Preliminary stages of making some sliding sashes and cases. Probably 3 sliding and further fixed lights but haven't decided yet. These will be almost entirely made with handtools. I thought I'd make one sliding sash and post as a WIP if there's interest.
These windows will all be opening to a garden so I was thinking of integrating a roller fly screen into the design as indicated in fig 4. Has anyone done this before? The inside part of the metal housing of the fly screen runner would replace or be the staff bead and then further decorative wood casing go on the outside to hide the screen housing.
Here's a picture of a fly screen from our house. The screen housing in white here would be covered and I'd change the bottom piece to look a bit nicer. The upper mechanism would be hidden in the head lining.
I usually print out parts of Ellis's text rather than writing over my copy. These out of print books are freely available
Brilliant, huge thanks in advance for this. I've been fascinated by this subject since I first lived in an older house with timber sash windows and gradually realised how there must have been small scale, pre-industrial methods that could make them efficiently enough to be commercially viable.
Skip forward several decades and I have read what descriptions I can find, acquired most of the tools needed, but not yet found an excuse for having a go at making a window I don't need! But I shall enjoy watching you, I'm sure.
I echo Andy's sentiments. I have read the Lost art Press book on doors and windows and bought a few old wooden window sash planes but haven't had a chance to do anything with them. House built in 1940s so may redo some one day, but too many other things going on.
Finding the time is most of the battle and skill in making I've come to find. I've never had much luck in finding sash planes and they would certainly speed things up especially if a few needed making: but these can be made with relatively few handtools that probably most people, the ones using this forum anyway, will have.
This build will possibly be sharing time with a writing desk that I've just been informed needs to be made (with no more than a vague idea of dimensions etc, not sure whether I will be required to build drawers either)... It's quite nice though that writing is still a thing.
Another detail of the cased frame that will differ from Ellis is the sill. This will probably be more like the filthy one pictured with less close-to-horizontal timber. I plan to form a metal sill (probably copper) which would be attached to the vertical sill part or slip under it with a little upstand (like the concrete sill in the picture) to shed water though I haven't worked out the detail yet.
There are so many variations!
Here in Bristol we have what I think of as normal, with a timber cill twice as deep as yours, coming out as far as the front vertical bead, and no external architrave.
In Bath, a lot of the Georgian buildings have sashes down to the stone cills, with no fixed horizontal timber.
Surely someone has documented all these variations in a handy textbook!
It will be good to see such a thread. I used to make them when I was an apprentice 45 years ago. I have made one or two since.
Now will you use lead weights or spirals? On a serious note will you incorporate modern draft proofing measures?
I have actually been to Bath. Beautiful town. But I only visited the old baths, walked around a church and ate somewhere that had giant hamburger buns as plates? I vaguely remember getting a cornish pastry before hopping back on the train.
I think you missed the best bits!
Weighted sashes to be used. I've a few old weights that were donated to me years ago by a friend so will hopefully get to use those. If memory serves correctly they were quite large diameter so I would think larger than I would need though maybe not lead so we'll see: I seem to remember quite a bid of surface corrosion. I have a lot of lead scraps so maybe could form some weights though I've never tried that before.
Planning on incorporating draft proofing which no doubt will complicate things with accommodating in housings and channels and changing measurements a bit.
I can't see how to integrate and hide a flyscreen without seriously weakening the boxed casings so might put that to one side for now.
Luckily I have found my old prototype piece of a previous pully stile (I usually keep old pieces) to help visualise and plan.
Cut list in process of finalising so hopefully will buy some timber during the week.
Interesting I wonder if you could use fishing weights. If you go to an actual fishing bait & tackle store seem the good ones have a huge range of lead weights. Though i suppose its easy enough to melt with a torch if you need to sand cast some.
I’m sure i missed a lot. Unfortunately the only time i have been to the UK was for work. We would stay in London, our office was on Bishopsgate downtown, but I would have to take a train to Slough where our datacenter was some of the times. So the trip to Bath was a quick stop after work but i had to get back (i seem to remember the last train was somewhat early)
I have a selection of CAD drawings for Sash windows that I plagiarised to use for my own purposes, attached is a PDF of one, which was for use on a listed and conservation project, keeping with single glazing but incorporating modern draft seals, it’s been a long time since I worked on this one, so I can’t be specific with regards the draft seals that were intended to be used, but it gives you an idea if nothing else.
I think if I'm in need of the additional weight I might try using up the scrap I already have. I hadn't considered a tackle shop. It's actually quite difficult to get weights in Northern Ireland and few companies are willing to ship over given the literal weight! My second method was to be using rolled up lead flashing which allows the cord to go through easily: not my idea but seems easy.
Brilliant, many thanks. This definitely makes things easier.
This is likely going to be at a leisurely pace. I thought I'd include much of the planning stage too as I sometimes find this the most challenging aspect, arguabley the most important.
Here is my cut list, reasonabley accurate. This will be further refined, especially lengths, when I start to groove and rebate the boards but it's a start. The cases comprise a sill, 2 pully stiles and a head piece (similar to the pulley stiles). They also then have inner and outer lining pieces (perpendicular to the stiles) and inner and out head pieces. The beads will probably come from off cuts but I'll buy an extra board or 2 anyway.
Top and bottom sashes are similar but not the same. The stiles are longer than half of the vertical reveal to accomodate horns (maybe 2 or 3 inches extra). The meeting rails are wider than the other pieces so that they can indeed meet in the middle (so I add on the parting bead width to each of these) but also a bit thinner so the middle portion doesn't look too unbalanced. The bottom rail is thicker than the other pieces.
I'll probably plane out a channel to recieve a carrier piece for the various brushes and seals as per @HOJ s CAD diagram but I'll need to get a few off cuts to see whats required. For completion here is a list of seals etc provided on another thread by @GaryR and @PAC1 which should cover US and UK.
https://conservationtechnology.com/building_weatherseals_components.html
https://www.mightonproducts.com/category/sash-window-hardware/staff-and-parting/
Undecided on the wood: possibly spruce or meranti or something else. I've used a lot of oak for recent work and would prefer to work with something else, not least to save a few pounds. Certainly the outside will be painted in linseed oil paint, may leave the inside natural but not decided on that yet. I think, as long as the exterior is properly protected, sheds water well and can dry out, it'll probably last well enough. Could even just use the most durable for the sill only.
Very short post to say this project is still alive. Finally got around to getting some material. Went for oak in the end. This is mostly European (french and german) as it's quite boringly featureless and easier to work compared to homegrown. A few homegrown pieces also included however for the thicker pieces. Today is roughly sawing to length and prepping for plane work.
Enough for a window and a bit. The sappy stuff is extra bits thrown in for free.
In the meantime I moved my bench and did a serious tidy up. However I've lost a full set of cutters in the process (hopefully didn't bin them somehow). It's a second set as I like to have 2 planes set so that I don't have to adjust as often when ploughing grooves. Ah well, hopefully they'll turn up. It's funny how I could immediately find them when there was more clutter.
Have you tried putting away the set you have? Or does that only work when you buy a new set and go to put that away...😏
That's a common affliction, I'd say applies to many here too!... I've ordered another 3/8" which is what I'm especially missing so we'll see what happens
Just back from a holiday yesterday so got a chance today to progress a little. I'm planning to put a fair bit of detail into the steps involved so hopefully that will be of interest. At the very least it's a reference for me for future builds so that I can reduce the thinking time.
Start with the box, the main parts being the stiles and head and work these 3 pieces at the same time for efficiency but mostly for accuracy: in other words, each step is applied to each piece before moving onto the next. They're all the same and follow this profile. As ever, trued, squared, well prepared stock is a must to get the best result. However, I don't bother much with the inner face (portion next to the weights) of these pieces, except to get the final width of the top left tongue. The diagram shows the order of cutting grooves. I basically cut all these as grooves and then remove additional if the final bit is a tongue/rebate (hopefully that makes sense). So 1 groove, 2 tongues and a tiny rebate to form.
Set the mortice gauge to the cutter width and strike the lines for the parting bead. Ideally work as much from your chosen edge.
From the diagram the parting bead is not quite in the center of the stile:
Grooves form quickly and give lovely thick shavings ideal for the fireplace
I don't bother with the back of these pieces yet as no gauge lines depend on that edge so the rough bandsaw marks are left and the only visible wood will be the inside face alone (sometimes there's more to life than a load of hand planing). These boards are roughly 32 to 33 mm thickness
Score for the tongue on the outside edge and plough a groove
If the groove depth is correct, then the thickness of the space for the sash is arrived at (40 mm in my case). That little portion at the top left will be chiselled and planed off. The casing, perpendicular to this piece, will attach to the tongue on the left, thus holding in the sash
Now put gauge lines for the staff bead (the 6 mm notch where the gauge is sitting in the picture) and to the right of that, the line corresponding to the inside edge and base of the tongue (top part of diagram above). Take these lines over top and bottom as well
Now cut the 3rd groove
the top left section of the photo above will be removed to form a rebate and then that little 6 mm rebate also formed for the staff bead.
OK, hopefully I'll finish forming the 2 big rebates and the small staff rebate soon.
To finish the stiles (and head), the chisel takes out much of the waste quickly. Still needs care to read the grain. Might require working in both directions or bevel down. This piece behaved well. The chisel is choked to prevent overrun.
When close to the line then a bench plane takes care of the rest (no need for the blade to be close to the wall of the tongue as there's a 10 mm wide groove)
The width of the staff bead can be marked in the bed of the rebate... (this width isn't critical)
Now the staff bead rebate depth (pencil at mark as line difficult to photograph) can be worked. This measurement IS critical as it determines the depth of the sash
A 6mm blade gets this
Work down close to the line. The straighter the grain the closer you dare to go...
Finish with a shoulder plane if you have one but I've done this with a chisel before
Here is the stile formed (modifications for weather may be made later). Ignore the vertical gauge line at the staff bead rebate, it's good!
I hope it's clear enough. Difficult to photograph the facets in this oak partly as the lighting needs rearranged and improved.
The casings are all basically just grooved. Internal and external casings have a 3/8" x 3/8" groove ploughed the same distance from the edge which in this case is 5/8". Therefore the outside casing overlaps the stile by 5/8". It will be moulded later (probably). The inner edge of the inner casing should end up flush with the little rebate for the staff bead: the staff bead is the equivalent of the outer casing overlap.
Plane up your boards. The width will be decided later (depends on a few things but the most important for me is the weights which I don't have to hand yet)
From the point of the balde to the tongue is 5/8"
I transfer this onto the casing piece
and use the mortice gauge set to the 3/8" cutter size
I score this several times so it's good and deep to prevent the cutter tearing out any grain running out to the side. You want that line on the left to be clean as it will show. The other line will be hidden so less critical
Before that point it is useful to check this on a piece of scrap which can test fit to the pulley stile
My setup for ploughing
Here's a pulley stile offcut with a casing piece not grooved to full depth. This would be how the inner casing would sit
and here's the outer
The fit is a nice push fit which should be self supporting but not overly tight
A shoulder plane is useful to soften the edge
Here are a few shots of the casings and stiles knocked together
Just need to make the sill and then cut pieces to final length. The sill requires a little more thought.
