Domi-not
For those who aren't aware, Festool's main Domino patent expired a month or so ago. That probably means that there will be lots of Domino clones on the market in the near future (Kreg have announced one already).
At the moment, the idea of a Domino machine doesn't really appeal to me: I'd rather do some joinery with a chisel than listen to a machine screaming its way through a bit of wood. Nevertheless, I can imagine the odd situation where it could be handy for rough stuff where I just want to stick stuff together fairly quickly (but not so quickly that a screw would do the job :) ). That's definitely not enough of a justification to think about spending Festool money (or even Kreg money) on a machine.
However, it was enough of a justification to spend £9 on a 3D-model from JSK:
That's with the fixed fence fitted. I've also printed the adjustable angle one (for mitres and such-like). The plans also included some fixed bases (which you can see in the picture at the JSK link) so you could support small workpieces while using it, but I haven't printed them.
So, how does it work? Noisily! Well, it is a screaming monster after all :LOL:
This is what it looks like in use:
I'll never be a youtuber :). That was a bit jerky as I pushed the router in, but that was mostly me trying (and very nearly failing) not to trip over the camera tripod!
I had held a couple of bits of wood next to each other and drawn a couple of lines across both in arbitrary places. In each of the bits of wood, I lined the pencil marks up with the lines built-into the 3D-printed fence thing and attacked. The (Trend) dominos fit perfectly:
There is adjustability built into the jig (by tweaking the size of some simple spacers) but for me it worked with the default sizes.
Offering up the other part:
and closing the joint:
Quite impressive for a 3D-printed doodah.
I also tried doing an end-grain joint and that didn't line up as well. Given how well the dual domino face grain one worked I'd guess that was down to my inept technique rather than anything inherent in the tool. If it turns out to be the tool, then it should just be a case of tweaking the spacers.
Is this a way to get a Festool quality machine for free? No, of course not. I've never used a Festool Domino but I'm sure it's far, far more polished than this printed thing. However, for someone like me who would generally rather cut a traditional mortice and tenon, the number of situations in which a Domino would come out would never justify the cost.
Also, the printed thing isn't free. The 3D model costs about £9, then there's a shade over a kilogram of filament (so about the same cost again) for the bits I printed (i.e. excluding all the bases and stands) and finally some hardware to buy (linear bearings & rods, springs, screws etc). I had some spare linear bearings of conveniently the right size left over from my wood lathe duplicator and I've got a healthy collection of springs and screws so the only thing I had to buy was the 8 mm router cutter, but starting from scratch it would cost a bit more.
Was it worth it? Who knows whether I'll find a need for it, but it didn't cost me much and it's nice to have a variety of tools in the armoury.
Brilliant!
I feel the same way about machinery - it's not what I enjoy using, but for anything on a bigger scale or just needing to be done quickly, something like this looks ideal.
It's enlightening to see how you can make something that big, complex and (presumably) accurate on a hobby 3D printer.
What's the material like in terms of rigidity?
I only found out today that car engine inlet manifolds are made of plastic nowadays, which is presumably rigid and somewhat heatproof. Could you 3D print something comparable to that? Or is your cunning device more like Duplo in strength?
(I don't mean that in any disparaging way, just as a well known material.)
Brilliant!
It's plastic, so it's never going to be as tough as a metal thing, but there are different plastics you can print with.
JSK did his in PLA, which is cheap & rigid but quite brittle (i.e. it'll break rather than bend). I tend to print everything (including this) in PETG, which is less rigid but will flex a little before it breaks, so is more suitable for tools & such-like I think. You can also print in ABS, which is what a lot of car parts are made from. That's stronger again & has enough flex to survive abuse.
All of them, however, are far, far stronger across a layer (as printed) than between layers. For heavy-duty stuff, part of the art of design for 3D-printing is about making sure the likely forces are dealt with by individual layers rather than layer boundaries.
All that is a long way round saying that it seems fine to me! For accuracy it relies on the linear bearings (which are metal), with the plastic just holding them in the right place. The trim router obviously does all the hard work.
Interesting Al. I saw a reference to that a little while ago and looked but felt it wouldn't be accurate, I might well have to think again.
JSK reminds me of a contemporary Bob Wearing. His 'jigging' is constant, inventive and reflects modern materials, whereas St. Bob of Wem used mainly hardwood and ply.
Nice bit of kit, Al and thank you for the filament comparisons.
It's always nice when people sharing printable models include STEP files. That makes it easy to make customisations. In this case, I've modified the vacuum port to take my Cen-tec vacuum hose, which is much less cumbersome (and spins freely in the tool port without any risk of falling out) than the other ones I have.
Looks excellent mate. Looked like it was very wobbly initially so I feared accuracy would be poor, but if that was just hand movement rather than plastic deformation then looks good. The end result looked good, and if, as you say, you only want it for the odd thing then it looks like it will do the job. Plus you got to be creative and have a little fun making it. Win, win!
Just think of the 'fun' you could have with one of those Mark:ROFLMAO: - Rob
Yeah, it was just me wobbling rather than it. I very nearly kicked the tripod over and was dancing with my feet out of shot, which didn't help with my control!
Thats awesome! I've kind of always wanted a domino but could never afford it. (I did almost buy the Rockler BeadLock system once) Same with their track saw. Almost did pull the trigger on the cordless tracksaw because the built in dust collection was so nice, but just couldn't pull the trigger. But something like this would help me when I just need to knock out some honey do item quickly.
I've looked at the Festool stuff a few times but with one exception I've never bought any of it (and even the thing I bought was reduced to about 1/4 price due to some minor cosmetic damage) - it's just too expensive for the use I'd get from it.
I do have the Makita cordless track saw and I wouldn't be without it now. It's great to do stuff with a Ryoba but sometimes you just want to rip through things quickly and the track saw is great. The (two 5 Ah) batteries seem to last forever in it too.
