The next big job that ought to keep me off the streets for a few months is an iconic 'Silver Chest' first made my Jim Krenov in 1961. He revisited this design several times and no two are the same; all are different:
This project is reputed to be a bit 'tricky' and one person on InstaG mentioned that he had never seen it repeated, though there is a detail shot of one in Maple on Pinterest. The difficult part is making the drawers and I really spent a long time trying to figure out how the cunning old bugger made them. However, once I made a trial drawer in some disgusting, nasty shed pine, I could see exactly what he did and it does actually work perfick:
Having purchased a 12mm sheet of Wickes rather good ply, I cut off two chunks for the top and bottom of the carcase and squared a corner on each true and dead accurate on the shooting board with my trusty LN51. The exact dimensions were then transferred using a steel rule, 4H pencil and one of those handy 'B' squares from WH to act as a square reference against the edge:
The waste was trimmed off, so it was then the turn of the router and a 90deg jig to true one of the edges which was then repeated for the final side using a mirror image jig and you can see (arrowed) the cut is spot on the line and will be dead square:
Using a bit of Ian's (Cabinetman) beech, both square corners/sides were lined up and clamped to the timber with three clamps (one not shown). The previously machined piece was uppermost and a top bearing cutter fitted in the router. A quick whizz round on the final two sides on the lower bit and viola:
....two accurate, dead square identical bits of ply. This is basic, very straight forward router stuff and makes a tricky job by hand absurdly simple and quick. Time spent in setting up is time well spent - Rob
