Joint Practice
I've been doing some practising of joinery. I've got to the point I'm relatively comfortable with dovetails (through, half-lap or tapered sliding), lap joints, M&T joints & housings, but bridles are one that I think of as being particularly irksome.
I'm sure it's partly down to the huge angled ones I did on the garden table, but getting a good fit does seem more awkward than some other joint types (mainly due to cleaning up the inside faces).
Anyway, I've done a couple of attempts & they both went okay:
The beech one (on the right) wasn't quite perfect but that wasn't because of the joint: it was because I stupidly picked a bit of wood that wasn't square and of even thickness (and I didn't bother to check). The side uppermost in the photo looks fine but the lower side is sub-flush on one side as the piece of beech tapered. I didn't bother to glue / clean up that one.
I was very happy with how the ash one came out (after gluing together with home-made liquid hide glue & cleaning up with planes):
That success inspired me to be brave and try an even more difficult joint. This one was quite a challenge & the result is a very long way from perfect but as a first attempt I'm quite pleased:
(Sweet Chestnut & Cherry)
8 second video showing all the sides:
I think I'll have another go at that joint to see if I can improve my technique.
I think you've got it sussed!
I've only done a few bridle joints and I agree that they do feel harder.
I've done hundreds of bridles, and they are definitely the most difficult of the standard joints. If I were setting a woodworking test for someone, it would be to make a bridle joint. And yeah, those dovetailed-all-round scarf joints are fun, aren't they. The first time I saw one I puzzled over it for 10 minutes or more trying to work it out. Once you know, it's obvious.
What's your preference with the bridle joint for separating the waste?
- Drill an undersized hole near the end, freehand, coming in from each side, then pare back to the lines?
- Drill a full sized hole by machine, bang on target, leaving minimum to be pared away?
- No hole, just chop out the waste with a mortise chisel from either side.
It depends on the size. If it's a massive thing in a green oak beam, then an undersized hole. If It's small and set up to a chisel-width, then chop out with a chisel (actually, I'm perfectly happy to use any old bench chisel, and seldom use a mortice chisel). I can't recall ever drilling out exactly the right size.
Indeed. I made one many years ago out of aluminium & brass. That was mostly an exercise in making a custom angled dovetail cutter for the milling machine (which then does the work of giving accuracy): none of this hand tool nonsense when cutting metal!
I'll definitely have (at least) another go as I don't feel I've got the technique right yet.
I can't remember what I did on the huge ones on the garden table, but on these two I used a fret saw to cut out most of the waste & then a chisel to pare back to the line.
An undersize drill or mortice chisel would be fine, but I didn't bring either on holiday with me! I don't think I'd ever be tempted to drill to size.
I bought this course from Richard Maguire and he has an interesting way of making these angled bridals reproduceable ( he can make them and they are interchangeable. I only got as far as making the guides but need to fine tune them, then got sidetracked on other projects.
As for that complex joint, reminds me of that impossible mallet that Abe Lincoln supposedly had.
Interesting to see that bridle joint jig: it reminds me of the jigs in this japanese woodwork book and is also similar in concept to the 3D-printed ones I made to help me learn dovetailing.
I think I watched that mallet video a few years ago, although the details have slipped from my leaky memory! One for another time perhaps: I've got quite a few more practices to do already lined up.
