I was carving the stretcher, last time I posted........
On the first side, I did all the lower parts of the letters one way up, then turned the wood around and finished off with the words upside down:
It's a long slow job, but gently speeding up:
The paper has to be well stuck down with Pritstick, so removing it is a bit tedious. I found a card scraper works best:
After removing the paper, you get to see all the stuff which needs tidying up. That takes a while. The net result looks OK to me, though:
Actually, that makes a point. You can't read that as there is no contrast. However, stand it up and you get shadows:
A close up of a random section:
........which if course showed up some more cleaning up!! It's done now.
I had also glued up the second pedestal one evening. Here it is with the pegs un-trimmed, and chalk indicating glue squeeze-out for cleaning up:
Here's that pesky knot after being filled and cleaned up:
I assembled the two pedestals, and checked for squareness etc:
On to carving the other side of the stretcher. I had done the last few letters of the other side a bit differently, and it proved a lot quicker and neater. Let's show you a close up of the process. Focus on the "O":
The previous letter looks scruffy, but it isn't. That's just carving detritus, and managing that is important. You quite quickly can't see what you're doing. So, back to the "O". I chop out the big straight bits first, with a 1" chisel:
Then I take a V gouge and come in from all the points, and down any (future) valleys:
Then the mallet goes down, and the rest of the job is just paring. First with a 1/4" chisel:
Next I go down the valleys again with the V gouge:
Then I do all the curves with this incredibly useful extra-shallow gouge with a thumbnail grind:
You can do a curve of virtually any radius with the tool. Its disadvantage is it doesn't get into any points, so it can only go so far down any slope. You've now got the shape fully formed, and it is just a question of refining and cleaning up, with whatever works:
ONce I had finished the whole side, I stood it up so the light showed up any issues, and then spend an hour working along the length tidying up all the tools marks etc. I'm thrilled with the result:
Taking it inside for grown-up show-and-tell is an important stage:
All in I reckon there was 15 to 20 hours work in carving both sides. It gave me awful neck-ache. However, I am really pleased that I bothered, as it is going to make this table quite distinctive.
If I hadn't had to go and listen to my wife's choir give a christmas concert, I would have started the top. I mean, I suggested that as I went last year I didn't need to go this, but that didn't help my cause.......
