Playing about with a big tap holder part 1
AndyT
Bristol
Quite some time ago, I bought this nice old thread box and tap.
It's bigger than my others - 1¼" diameter - and if I am ever going to use it, I need something to hold the tap with. The top of the tap is tapered one way and slightly rounded so my metalwork tap wrenches won't do. I don't think I'll get far with a couple of spanners or Mole grips either. So I decided to make something suitable from wood.
I didn't have anything drawn out in advance but I found a bit of left-over hardwood (sweet chestnut actually) that I thought was about the right size and sketched out a shape on it, with the help of a cardboard template.
I bored out a hole in the middle
and chiselled away the surrounding wood until the hole was nearly big enough to let the tang of the tap in, but not all the way.
I thought that the edges of the hole would need some reinforcement. Steel would be good, but I decided that two bits of ⅛" thick brass would be ok and much easier to work. I'd already decided that in this project I was definitely aiming at 'functional' not 'accurately measured and consistent everywhere' so I cut another just-good-enough template and drew round it, then cut out the shapes. I do really need to buy a new marker pen that hasn't dried up.
I cut the shapes out with a hacksaw I actually bought new
and a somewhat older jeweller's piercing saw, probably made by an anonymous outworker somewhere in Lancashire in the 19th century:
I realised that I couldn't just use screws to hold these plates in place, as they would have to be rather short so as not to hit the screws from the other side. So I decided to rivet instead.
I marked around each plate and chiselled and routed away to depth.
Then I put the plates in and drilled right through both of them on my smaller bench drill, which likes to sit beside its bigger cousin ;) .
I opened out the holes with a tapered reamer. (The green ink on it was to make sure I went to the same depth on all the holes.)
Before fitting the brass plates I finished off the shaping of the wooden body. First I cut out the shape on the bandsaw:
Then it was a simple job of marking pencil lines for chamfers and shaping with one of my favourite spoke shaves.
I cut some bits of brass rod to what I hoped was the right length and hammered them down to form the rivets
and enjoyed that stage when filing and sanding makes them pretty nearly disappear:
To make the hole in the handle fit the tapered tang of the tap, I pushed the tap in, then filed away the marks on the sides of the hole, a little bit at a time.
As made, it's just about tight enough to be able to hold the tap so it doesn't fall out. If it loosens too much, I could always add a clamping screw from one side or line the hole with something grippy.
Having got this far, I couldn't resist trying it out. I bored a hole in a bit of scrap ash
and worked through with the tap
This worked quite nicely - I think the holder is about the right length to give plenty of torque but not too clumsy to use.
However, the tap didn't feel very sharp at all, certainly not as sharp as other, smaller taps for wood that I have. I carefully refreshed the edges with a saw file and some 400 grit paper round a tube.
That felt sharper on my fingers and I think it helped.
But I've hit the 20 photo limit, so I'll continue in a few minutes...
That's a very nice project. But I have to admit that old bench drill really stole my eye! I have never seen this model before, but what a beauty it is! Really wonderful. 🤤🤤🤤
A Bradston possibly Andy? I had one too. Admirable design and castings.
Well, there are two lovely old bench drills in that corner. (Ignore the electric drill, bandsaw, clamps, bandsaw blades, edging strip, cuddly toy... - space is precious!)
The little one in front, that I was using on this job, is by Millers Falls:
Here it is in a 1925 Millers Falls catalogue:
I think it was pretty much the bottom of their range, aimed at schools or hobby model builders. Although it's basic, it works at an accurate enough 90 degrees to the work, and for an easy job like a 3/16" hole into brass and wood, it's ideal. You do need to turn the handle at the top to advance the quill/chuck/bit down into the material being drilled, but it's easy to arrange something as a stop or add a clamp if you don't have another hand to spare.
The one behind, that Sam suggests might be a Bradson, is a bit of a puzzle. It certainly shares features with some Bradson drills - for example you can turn the main casting 90 degrees and bolt the table to a vertical wall if you need extra capacity - but I don't think that was unique to them.
There's a 1935 catalogue from them here https://archive.org/details/bradson-drilling-machinery/mode/2up - which tells us that they were first made by Thomas Bradley at the Alexandra Works, Accrington, then by the Lodge Engineering Co. Ltd but I don't have any more information than that. None of the pictures matches mine exactly, which is not to say that they didn't make it.
The frustrating clue on the drill itself is this elegant logo - RS or SR? If anyone knows, do please say. It could be the name of a dealer/retailer but I don't know who. I don't think it was Radio Spares!
The drill itself is satisfyingly robust. It does have a very simple but effective automatic feed. The shaft is attached to the quill but the free to slip. There's a pair of nuts and a washer on the top. If you do these up to the right tightness and lock them, you don't need to fiddle with it again - if the drill can't advance, the clutch slips, but in normal work it will feed down nicely. Very satisfying to use.
The previous owners of these drills couldn't wear them out and nor can I.
The one in front I have seen variations of, but the one in the back I had never seen. Thanks for the additional photos! I will definitely try to find more information on this type of drill.
Ah, that classic collaboration between Record & Stanley 😜 🤣
Here's a photo of my Bradson, which is a similar-ish idea I think:
Ok, drill spotters, I've found a few more pictures from when I bought it, 11 years ago.
It was superficially rusty:
but it was complete and sound. All I did was go over it with a wire brush, and use electrolysis on the easily detached base. I then brushed on some boiled linseed oil, diluted a bit with some white spirit.
Not quite as heavyweight as yours, Al, and lacking a safety cover for the exposed gears, but I like it.
And here's a pic from an old Tyzack catalogue of a similar model to show the alternative wall-mounting feature:
That is almost tool porn to me! Thanks for the pictures. If I ever encounter something like it I will definitely grab it for my workshop.
