Record lever cap screw
AndyT
Bristol
Over in the hand tools section, Rob (@Woodbloke) has been showing us his newly acquired Record 04 Stay Set plane.
Being a woodworker with higher standards than many, he immediately set about getting it into a fit state to remain in his workshop, with a complete clean, a new pair of handles and then a new iron. Along the way, he found that the replacement iron was actually thicker than first described, so there was a risk, helpfully pointed out by @Sheffield Tony, that the screw that holds it in place would be too short and so fail to engage properly with the frog. But where can one get a longer screw of the right thread and style of head?
The answer is simple if you happen to have a lathe about the place. Fancying the idea of a session in my playroom, I offered to make one.
So that I could be sure of the details, Rob posted me the original screw. I was able to confirm that it was either 9/32" BSF, or UNF (24 tpi). (At this scale I can't tell the difference and the two are interchangeable.) I could also measure the head and see that it is angled underneath so as to fit snugly against a recess in the cap iron, a feature that makes these screws definitely not an off the shelf fastener.
Here are a few photos and notes so that I can remember how I did it, and try and persuade anyone who is thinking of getting a lathe of their own to give in to temptation and do it.
First off, here's Rob's Record screw (centre) between a 1970s Stanley on the left and a 1920s one on the right, to show what I was aiming for. Neither of mine was an exact match, so it was worth getting the right one to copy.
The first step was to find a bit of suitable steel, get it central in the chuck and reduce the diameter of the head and body parts.
I took very light cuts as I sneaked up on something close to the right dimensions. Having the original to hand was a big help. I have a few BSF dies but not in this somewhat unusual size, but I knew I could do 24 tpi on any reasonable diameter with a single point tool.
My lathe is designed to cut a wide range of threads, but there's no quick easy gearbox. You have to find the right size gears and put them in the right places, like this.
Then, the best method is to swing the cross-slide around by half of the thread angle. That means you can do most of the cutting with just one side of the tool, which gives a cleaner finish.
The tip of the cutting tool has to be at centre height. One way to achieve that is to expose the tailstock centre and line up with that:
And here's the first trace of the point, confirming that it's properly set up for 24 threads per inch.
a bit more
and then part off
(Note that by this time I was relaxed enough to take an action shot!)
I then needed to put the screw into the chuck the other way round, so I could work on the head. I wrapped copper wire around to protect the thread and used a dial indicator to get it centralised.
To shape the head to a nice dome, I used files, freehand (sorry, no action shots of this as I ran out of hands) but to finish off I wanted to use a form tool made (not by me) from an old file.
This needed a flat platform for the file to rest on. I decided on a bit of scrap softwood resting on the bottom part of the cross-slide, but it needed to be held safely so there was a quick side project to drill and tap a hole in a bit of thick brass. In a pragmatic concession to modernity, this was M6, to suit a ready-made screw.
I don't know if the previous owner tempered this file, so I was very careful to take only tiny cuts.
I've said so before, but my first choice of tool to cut a slot in a screw head is an Eclipse 4S tool, like this one.
I used it, carefully centralised with a special shim:
and opened it out a little with a needle file.
So here's the finished item, side by side with the original. I left it full length so Rob could trim it to the exact length to suit his plane.
And that was a thoroughly enjoyable session, playing with one of my favourite toys, listening to music but fully absorbed in the process throughout.
Thanks again, Rob, for giving me a chance to make something potentially useful - it's always better to make something somebody needs.
Brilliant explanation Andy; I'm suitably impressed! The last time I cut threads on a lathe was in the late 60's on a big Colchester as an apprentice piece, which was a Toolmaker's Parallel Clamp. If if recollect the thread was an M6:
Current 'state of play' of the Krenov 'V' door cabinet in the background; more to do on the central glazing bar - Rob
That clamp looks just like my Eclipse branded ones!
It would be interesting to try something relatively sophisticated like a Colchester. But I suspect that I'd still prefer the perverse awkwardness of the Barnes and the way I can work largely by eye and feel. 😏
I was sixteen when I made that in the first year of my Plessey apprenticeship at the training centre attached to Highbury Technical College (as was), Cosham. The M27 hadn't yet been built at that time but nowadays it goes right past the College and if you closely:
...there's a long, single story block at the bottom of the pic (centre) parallel to the motorway. If I recollect, that was the old apprentice's training centre; the new buildings opposite didn't exist and the car park outside the training centre was full of Norton's, BSA's (with the obligatory clip on bars) Triton's, Triumph's , Matchless, Ariels etc motorbikes as well as goodly selection of Vespa's and Lambretta's including my GT200 - Rob
Those bike names take me back Rob, my mum wouldn’t let me have a motorbike so I ended up with an LI 150 scooter that was as old as me.
But thanks Andy that was most instructive, am I correct in remembering that yours is a manpowered lathe? Whatever it can still produce good work in your hands.
That's right, it's a Barnes 41/2, from Rockford Illinois. Probably late 19th or early 20th century, they were exported worldwide. Here's a general view of mine. (The tool holder is absent in this photo but you can see where it goes.)
Highly recommend and a lot of fun.
I am feeling pleased for my part in triggering such fun !
Lovely job, I wish I had room for some more metalworking tools. My father has a fair collection of metal working stuff (files, old taps and dies, arc welder etc etc) looking for a new home, but it just won't fit. That lathe is a very nice looking toy.
These screws are a bit of a problem, as it is now getting quite hard to source a thin plane cutting iron, rather than modern ones cut from 3mm or 1/8" (or even thicker) sheet material. I tried to fit a Clifton replacement SS lever cap and the famous wonky stamp hand forged iron into a Record #6, (the originals were missing) and the screw is just not long enough. I'm currently making do with an old thin Stanley cutter and the Clifton lever cap, with a replacement frog kindly donated by Bugbear on UKW, after the thread in the original one stripped.
Very cool looking machine Andy, lovely castings, maybe even I could manage to make something on one. I have always been a bit aggrieved that we weren’t taught metalwork at the schools I went to.
Apropos of nothing my wife was born in Rockford, the winters can be brutal so close to the lake.
