Shelf Unit
T....I can see that a plane would be quicker though. What sort of plane do you use for it? My shoulder plane would (I think) cut into (or at least rub against) the shoulder as it would be canted over at the angle of the tail. ....
Yeah, that's all I do, having flattened that side of the plane against the bench to push the blade inboard. Obviously because it's canted, it misses a mm or two of the face of the dovetail in the acute angle, so a quick follow up with a chisel is needed.
You're both missing the chance to make or buy more planes... I'm sure I've written somewhere about using these and whether it was better than just chiselling, but I can't remember, so next time I shall just have to try again...;)IMG_20240513_083816.jpgIMG_20240513_083841.jpg
It has been more than six months since the last time I posted on this thread. The day after the last post, my other half (for whom I've made this shelf unit) had a really bad car accident and ended up in hospital for several weeks. She has mostly recovered now thankfully, although it'll a while yet before she's back to full strength.
When we left this last, I'd finished making the body of the shelf unit and the wonky piece of plywood (the "banana") for the back had been handed over to Carolyn to paint or otherwise finish. Unsurprisingly, that wasn't a top priority for her while in hospital.
Anyway having mostly recovered, she has now decorated the plywood (using a nice old relief map of the Lake District, of which we have several). The first job (after oiling the frame with Mike's Magic Mix) was to fix it in place, which I did with rather a lot of 3 mm Torx-head screws in order to persuade the banana to become flat.
This is the unit sitting on the bench:
Our favourite mountain pops up just above the top shelf:
The last thing to do was sort out mounting it on the wall. I was nervous about drilling two holes in the wall and getting them perfectly level to the ground, so I decided to design some adjustability into the brackets. When I actually came to mount the shelf unit on the wall, it was spot on level without any adjustment, but the adjustability certainly won't hurt (and might be useful if the unit ever moves and I'm less successful with drilling).
I started this piece of brass, from which I cut a couple of small slices:
The first job was to bring the bandsaw-cut sides parallel with one another, so I mounted each piece in turn on thin parallels in the milling machine vice and skimmed the first edge with a 12 mm end mill...
... then flipped them over and did the second side:
The parts then got mounted together in the milling vice and I used a 6 mm slot drill to make three short slots:
A 9 mm end mill turned the middle slot into a keyhole shape and also made some relief (3 mm deep in the 5 mm thick part around the other two slots):
The brackets were then flipped over and some relief was milled in the central slot:
After a quick deburr, I gave the parts a quick rub on some 240 grit wet-and-dry paper to clean the faces up a bit and then I was ready to call them done.
The brackets are 12 mm wide and 5 mm deep; the shelf unit sides are 16 mm wide with a 5 mm deep rebate for the back. I thus needed the brackets to be 2 mm from the outside edge so that they were central in the side pieces or there would be a risk of them being visible. The first task was to pick a location for the brackets and mark the top and bottom locations:
I used my edge distance gauge thing (set to 2 mm), a knife, a square and some chisels to hog out most of the material, then went over the bottom surface with a router plane to get it nice and level:
With the bracket fitted tightly in the correct location, I could mark the centre location of the mounting slots:
I then extended the slot by a couple of millimetres above and below the bracket so that the entire bracket can be slid up and down as required, but the centre of the slot should be in the "nominal" position. This photo shows one of the brackets fitted, with a screw (not the ones I used for mounting: they were a bit longer) in the keyhole slot:
With that, done, I could call the shelf unit finished and get it mounted on the wall. Once it was mounted, Carolyn loaded it up with the stuff she wants to keep on it and it was ready for a couple of final photos:
Why have you left a spider hidey spot to the right? I detest spidders.
What's wrong with spiders? They catch flies!
As to why, the walls aren't anywhere near straight, so mounting something that's got right-angles everywhere and is level to the ground would result in it not sitting flush to the wall at the side. More importantly, putting it there is what I was told to do ;)
Ah, the under instruction excuse / reason rolled out. Fair enough. I am familiar.
I prefer the term spidder. It sums up their repulsiveness. Hand held vacuum cleaners were invented especially to deal with them. And anyway, how do you know that spidders don't attract flies? It's a chicken and egg thing in my opinion.
I new an old lady who swallowed a spider, that wriggled and tickled and tickled inside her. She swallowed the spider to catch the fly, I don't know why she swallowed the fly. Perhaps she'll die.
(Apologies to Burl Ives :))
Nice idea with the map and a neat solution for adjustable hanging.
I like spiders as they make me appear brave and manly when the other members of the household scream for me to deal with them.
