I have a couple of workshop air filters. They are on 13 amp plugs but there is no separate switch, they have to be turned on and off at the wall socket. Where I am about to instal them the wall socket will be awkward to lean over to all the time. So I'd like to wire a switch into the power cable. The switch will need to be in a box, not exposed at the back. Does anything like this exist that is just a switch rather than an NVR? Like this:
https://www.axminstertools.com/kedu-kjd ... box-600072 but as just a switch
NVR seems overkill as it doesn't matter if it turns back on after a power failure. Fall back will be a something like this:
https://www.tlc-direct.co.uk/Products/C ... gJnsvD_BwE
But I would prefer push buttons rather a rocker (or rotary) hence the question.
Many thanks
Many thanks
