Cabinetman
- Joined
- Oct 11, 2020
- Messages
- 5,533
- Reaction score
- 1,233
- Location
- Lincolnshire Wolds + Massachusetts
- Name
- Ian
I once had a blower and the skids held up very well, that is some damage.A very simple little 5minute job that made all the difference to snowblowing our very uneven drive, the metal skids were just about worn away so I’ve fitted these hard plastic ones with wheels, how long they last? We shall see.
View attachment 39550View attachment 39551
I'm late to this thread. In January 2025, my 2018 Ranger did not like the cold of the garage and was sometimes difficult to start. I thought it might be the glow plugs, so I took it to the dealer. The glow plugs were fine and the problem was the original battery. The dealer installed a new battery while I waited.Wonder if it would be that easy on my Ranger, I'll have to take a look because that definitely does NOT like to start when it's zero and below!
Looks familiar.My washing machine started making a terrible noise today while on the spin cycle so I stopped it and had to remove the filter so I could drain it to be able to open the door and empty it.
It sounded like something was rattling around between the inner and outer drum, I turned to Google which said best way to access it was by removing the heating element.
I pulled out the washing machine, took the back off and removed the element but couldn't see anything.
Googles next suggestion for getting inside was removing the sump, I had to turn the machine on it's side to remove this but still couldn't find anything in there.
Next suggestion was using a cable tie to poke down between the front of the drum and the seal, I tried this and eventually found something in there which was rattling around causing the problem, it had got in there but didn't want to come out.
After a long battle I finally removed the culprit using one of those magnetic pick up tools, if only I'd taken more care checking my pockets I wouldn't have wasted 2hrs of my Sunday afternoon.............
Thee and me Andy. SWIMBO is an utter menace for stuffing her jeggings pockets with bits of kitchen roll that disintegrate in the washing machine. "But I get them from work" is her only defence so of necessity I have to check all pockets before loading the washer - RobThe amount of time I spend removing remnants of paper tissues from the WM !
All the kitchen rolling I use doesn’t disintegrate in the wash, it stays intact and you can reuse it, paper tissue has no glue in that’s the problem with it.Thee and me Andy. SWIMBO is an utter menace for stuffing her jeggings pockets with bits of kitchen roll that disintegrate in the washing machine. "But I get them from work" is her only defence so of necessity I have to check all pockets before loading the washer - Rob
Parsimonious Pete!All the kitchen rolling I use doesn’t disintegrate in the wash, it stays intact and you can reuse it, paper tissue has no glue in that’s the problem with it.
Rice isn't the best way a night in the aring cupboard is best or on top of the boiler.Ive deep cleansed keyboards by prising the keys off( take reference photos first!)
Keys in a pillowcase into the washing machine then towel dry.
Wipe clean dry the base then clip them back in.
Maybe worth trying as a last resort
Drowned phones have been restored by burying them in a Tupperware full of dried rice for a week.
You could do it with the crystals from a disposible dehumidifier
A combination of both methods ?
If I spilled whisky on my keyboard, I'd only be able to type asterisks for a while. Possibly in groups of four.
Wow…..that brought back some memories.But that reminds me...
so large PCBs stuffed with 7400 series logic gates).
Negative take on a chopsaw so it doesn’t pull the wood up.I'm no expert, but I thought the tooth geometry was different re. mitre saw/table saw.
